| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#321 |
Finished ML3 but noise is coming and it is more audible when bass mid and treble are at full
but awesome treble and bass i have grounded every thing properly Dirty distortion is coming when volume pot is at full even though the input mobile volume is low any way this will spoil the original quality sound of ax-14 Last edited by comasus; 12th May 2012 at 03:58 PM. |
#322 |
Must assemble in proper case;
Must revise power supply quality; Not to mention proper wiring. IMHO, Max.
All the best, Max.
#323 |
#324 |
#325 |
see page 1
#326 |
Hello, sir Mile. I have same problem with my ML3 project. Everything is properly connected and the ground is also in one point. When the volume is full i have big distortion without signal. All potentiometers are B10, i think they are linear like in your schematic, but i'm not sure. Can you response what change we can make to reduce this noise and distortion. Thanks.
#327 |
#328 |
hello apex
1. for b500 how gain required in ac volt? 2.for ml3 how gain required for input (ac)and what output on ml3? 3.how gain required for h900 ? |
#329 |
hi ... apex
x-over you may be used for sound field? |
| help with single supply for two EQ/preamps | lassoharp | Power Supplies | 3 | 9th July 2009 03:24 PM |
| HELP with PHONO and MIC preamps. | P Lazkao | Tubes / Valves | 10 | 23rd June 2006 01:42 PM |
| measurement programs, mics and mic preamps. | j.burtt | Multi-Way | 11 | 15th November 2005 08:08 PM |
| Power supplies in mic tube preamps | JamMan | Tubes / Valves | 5 | 2nd November 2004 02:48 PM |
| mic preamps | travis | Solid State | 7 | 20th May 2002 05:59 PM |
