| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#281 |
Hi apexaudio
Plz post schematic of Balanced line input with low cut 12dB/oct at 35Hz |
#282 |
On ML3 these tone control pots (bass, middle, treble), can I use pots with center point? With all tone pots turned to center position, sound should be unchanged, e.g. same as from source?
#283 |
UPDATE: Just finished one pair of ML3 for TDA7294 amp and works like a charm. Big thanks, Apex.
#284 |
Hi
I need a diagram and PCB for an active filter for the subwoofer amplifier: "Quasi amplifier for beginners" (of APEX Audio). Regulated frequency of 40...120 Hz with a slope of 12...18dB. This preamplifier that can directly to be connected to output to my stereo amplifier. Thanks for your help Last edited by formula 22; 23rd September 2011 at 06:50 AM. Reason: Schematic fo preamplifier for subwoofer |
#285 |
Hi apex. I have made apex ml3 pcb. This is the result. Quality is good enough. But i had a little hum, but when i touched the casing of my amp, hum was disappear. Can you give me any advice for it. How to wiring apex ml3 correctly? I just used simple regulated power supply. Thank you very much.
#286 | |
http://www.facebook.com/APEXaudio.MileSlakovic |
#287 |
#288 | |
Can you share pcb lay out in pdf format? How to make this preamp to 4 adjustable potensio (high, mid, freq and low)? regards Endik |
#289 |
apex,
please help how to put balance pot , i will use ML3 as multiple input maybe 4 or up ML3 and feed it to MX1, i just hope your help of adding a balance pot to assign left/right to MX1 as master and ML3 as multiple input, hope you help |
#290 |
Thank you Mr. Mile,
This is my ml3 sound ok but i will add 1 potensio for mid low freq, can some one help me? Thank you ImageShack® - Online Photo and Video Hosting
| help with single supply for two EQ/preamps | lassoharp | Power Supplies | 3 | 9th July 2009 03:24 PM |
| HELP with PHONO and MIC preamps. | P Lazkao | Tubes / Valves | 10 | 23rd June 2006 01:42 PM |
| measurement programs, mics and mic preamps. | j.burtt | Multi-Way | 11 | 15th November 2005 08:08 PM |
| Power supplies in mic tube preamps | JamMan | Tubes / Valves | 5 | 2nd November 2004 02:48 PM |
| mic preamps | travis | Solid State | 7 | 20th May 2002 05:59 PM |
