Phono Preamp Problem.
Old 13th May 2010, 01:04 PM   #1
wjlamp is offline wjlamp  Greece
Default Phono Preamp Problem.
I have a mc only phono preamp,that from time to time, refuses to sing. And sing it is.
It is an Elector design from the mid 80's. It features a balanced input and the active devices are relaively old school,but respectable non the less. BB OP 27.
It is made with near the top of the food chain materials,bar two small polyester capacitors that decouple power supply lines.
Upon firing up the unit the one channel is sometimes muted,and sometimes not. Being operated with a removable top,and accidentally touching the small poly cap one day,it came back to life. The same thing goes on for a month or so now.
Not being an electronics engineer,I seek friendly advice,of what might be the problem.
Any input will be gladly appreciated.
BTW. The preamp sounds fantastic to my ears,and I want it back in circulation.
Thanks in advance
B.L.
Old 13th May 2010, 01:18 PM   #2
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Exchange or resolder the poly cap. Is the OP27 hot or very warm ?
Old 13th May 2010, 02:00 PM   #3
Thanks a lot.
I am not in the position to say yes or no now. The preamp,is disassembled 'cause,I am changing the external box and the input connectors,and cannot test. Come Sunday...
Tks once more
B.L.
Old 16th May 2010, 03:17 PM   #4
Thanks Mr. J.G. for the instant diagnosis and the proposed solution.It was the cap. I 've change them with new ones (both channels) and it is back to normal.
Obliged
B.L.
Old 16th May 2010, 06:45 PM   #5
Wow, i am happy that is works.
Phono Preamp Problem.Hide this!Advertise here!
Phono Preamp bayermar Tubes / Valves 51 18th November 2009 04:04 AM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
Which phono preamp ? yagoolar Tubes / Valves 5 26th January 2005 10:50 AM
Phono PreAmp JTT Analogue Source 20 15th September 2004 04:24 PM
