Go Back   Home > Forums > Source & Line > Analog Line Level
Old 14th April 2010, 01:15 AM   #1
col is offline col  Australia
col's Avatar
Default mono/stereo switch?
What is the simplest way to implement a mono/stereo switch?
Is it just a case of summing the two channels using resistors on one side of the switch and having the other side bypass the sum?
any options on this or opinions?
cheers,
col.
http://www.minirig.org.au
Old 14th April 2010, 01:22 PM   #2
It depends of where in the audio chain monoize (?) the signal
Old 14th April 2010, 01:31 PM   #3
depends on the purpose.
If you want two mono channels and don't require the stereo signal, then simply short together the two channels with a single pole switch or relay or dual FET.
If you want a mono channel for some thing and still require the stereo channels, you need a sum circuit that combines the information without cross coupling the stereo signals. An inverting opamp topology with two input resistors does this. This would typically drive a mono sub woofer.
Old 14th April 2010, 02:59 PM   #4
dannybeckett's Avatar
This is exactly what I need as well. Andrew could you find an example? This is what I planned
Old 14th April 2010, 04:35 PM   #5
lauret is offline lauret  Netherlands
lauret's Avatar
Check this article on passive summing: Why Not Wye. Caveat here is the introduced crosstalk on a parallel stereo output. To get around that, use a opamp based summing amplifier.
Old 14th April 2010, 07:48 PM   #6
mjf is offline mjf  Austria
hello.
here are two examples,one active with opamps
and the second one with a simple on/off switch (and two protection res if needed).
greets
Old 14th April 2010, 09:36 PM   #7
thanks for that!
Old 14th April 2010, 10:09 PM   #8
col's Avatar
Thanks for the replies. I'm retro-fitting an early 90's amp using a modern pre-built amp module and want to get as many of the old amp switches and functionality working as possible. I am looking at monoing the signal after the chassis input connectors before the amp module inputs. Both channels will be either stereo or mono (unbalanced).
Will try the examples given (and read the Rane note again).
cheers,
col.
Old 15th April 2010, 01:47 AM   #9
Joachim Gerhard's Avatar
That´is the way i do the Mono / Strereo switching in my preamp
Stereo to mono... mcelaj Solid State 12 17th December 2011 04:57 PM
An external mono switch Paul Ebert Pass Labs 2 10th February 2009 01:45 AM
mono vs. stereo schmalex Chip Amps 1 6th June 2005 01:51 PM
Stereo vs Mono profuse007 Car Audio 4 6th March 2005 08:25 PM
stereo to mono janey Solid State 3 12th December 2001 05:57 AM
Copyright ©1999-2013 diyAudio
