Go Back   Home > Forums > Source & Line > Analog Line Level
Old 9th April 2010, 04:36 PM   #1
acold7dusta's Avatar
Default Millet max as a preamp? schematics disclosed
Hey guys- I built Pete Millet's Hybrid headphone amp about 2 years ago, and i must say it's a great design and sounds great through headphones. It has been stated that it can also be used as a preamp, as well (although I don't know of anybody that does this). I have just finished building a pass F5 amp last week to power my thor's and using the millet max as a preamp (through the headphone out to RCA).
I guess since this is my first seperates system (had some receivers before) What sort of things should I listen to, to know if this will be suitable as a preamp? Don't get me wrong-it sounds great, but before I modify the millet max case, I want to make sure that this is a proper way to go.
It would be perfect to have a headphone amp that can be used as a preamp as well (to cut down on boxes + easier integration), but if that isn't the case my next project may be an aikido.
Thanks and sorry for the long post,
Kevin
Squeezebox Touch>Coax>MH Dac 25.2>Marantz PM-15S1>Seas Thor (Small)/Beyerdynamic DT770
Old 10th April 2010, 12:12 PM   #2
Gordy is offline Gordy  United Kingdom
Originally Posted by acold7dusta View Post
-it sounds great
Well, that's about it! If it sounds great then use it as it is.
Then, when you have a functioning music system, you can decide if you want to spend time and money trying to better it. I mean by building an altrnative, so you can then swap the new one in / out without having to rip apart your existing one, hence always having music available to you and having a known reference against which to judge 'improvements'.
If you find that you can only use a small part of the volume control you might want to build a second one without the gain tube, just a volume control and output ('diamond') buffer.
Perhaps others will be able to offer alternative ideas...
Mini Millet (starving student) and iPod?? bsquared Tubes / Valves 6 28th October 2010 10:19 PM
Millet Hybrid - stacked buffers woodturner-fran Tubes / Valves 2 20th November 2007 09:07 AM
Contacting Pete Millet for 813 PSU? cwujek Tubes / Valves 2 18th September 2007 02:31 PM
Hybrid Amp from Pete Millet tinitus Solid State 0 7th July 2007 03:52 AM
Peter Millet amp dtaylo3 Tubes / Valves 0 4th March 2007 05:41 AM
Copyright ©1999-2013 diyAudio
