Building my own 10 Channel Preamp
Old 14th April 2010, 06:19 PM   #11
the two summing resistors go to the -IN pin, the inverting input.
The feedback also goes to this -IN pin.
The +IN pin should see the same impedance as the -IN pin to minimise output offset and offset drift with opamp temperature.
If you use three 10k resistors on your inverting summer, the -IN pin resistance is 10/3 k and the resistor load between +IN pin and Audio Ground should be ~3k3 for minimum offset and drift.
Why are you using opamps on the inputs to the pre-amp?
If the outputs of the pre-amp need buffering then the opamps should all be on the outputs not the inputs.
regards Andrew T.
Old 14th April 2010, 06:40 PM   #12
Mooly's Avatar
Good point Andrew makes about the offset problem, particularly as you are using electronic switching. Any difference in DC levels as you switch them will cause clicks and thumps in the audio.
If you use FET opamps (which I did...OP2604) there is no problem as the input currents are virtually zero (thus not developing a DC offset across the input resistances) . If you use bipolar types such as NE5532 etc then yes, it's a real issue.
Old 14th April 2010, 06:43 PM   #13
dannybeckett is offline dannybeckett  United Kingdom
dannybeckett's Avatar
Hows this:
Can pretty much use exactly the resistors u said as well. What would an inverting 0 gain amp circuit look like? Because I will have to invet the signal again wont I?
As for the first set of op amps, I'm just following this design - High Quality Audio Preamp
Those first op amps actually provide a gain of 6dB =]
Dan
Old 14th April 2010, 07:05 PM   #14
read this again.
regards Andrew T.
Old 14th April 2010, 07:06 PM   #15
my bad
Old 14th April 2010, 10:39 PM   #16
Will the circuit not work the way I have illustrated?
Old 14th April 2010, 11:08 PM   #17
Xoc1 is online now Xoc1  United Kingdom
Xoc1's Avatar
The point is when used as an inverting op amp, the inverting input that is connected to the input signal resistors, and the feedback loop resistor is always kept at a very low signal level (practically zero) by the feedback applied to the op amp. This VIRTUAL EARTH is what stops the input signal from one channel bleeding across to the other.
Old 14th April 2010, 11:21 PM   #18
I understand. How's this -
Old 15th April 2010, 07:21 AM   #19
Mooly's Avatar
Yes... and if it's a FET opamp the 3K3 isn't needed and can be linked out.
Old 15th April 2010, 09:53 AM   #20
Beware: this is a summing amplifier.
If R=R=R then Vout = V1+V2.
The mono signal is nearly twice the voltage of each of the stereo signals.
regards Andrew T.
Building my own 10 Channel PreampHide this!Advertise here!
Building the Nathan 10 markus76 Multi-Way 872 4th December 2013 06:13 PM
