| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Looking to replace this on a sm pro audio Pr4v. Looking to improve the circuit. Any help much appreciated.
#2 |
You could try the NE5532. I've had pretty good results with those.
Hari |
#3 |
As Hari mentions the 5532 is fine although DC precision is not it's forte and it's a little power hungry (relatively speaking) compared to the 4558. If you are changing several then it's an important point. It also needs care with decoupling too for absolute stability.
IMO you honestly can't go far wrong with the TL072 as a drop in replacement, and as always it would help to see exactly what the intended application is (circuit diagram).
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#4 |
Almost anything else would be an improvement
![]() In your application (mike preamp?) I feel that a dual low-noise OpAmp will do. My favorite is LM4562 (it is unity gain stable so no surprises there, doesn't draw a lot of current like other higher-performance parts). |
#5 |
4558!! and that crap is in production!
SM Pro Audio: PR4V - 4 Channel Microphone Preamp Those conductive plastic pots must be the cheapest as well? Ergh.. |
#6 | ||
Isn't the marketing a powerfull tool?
This days I woldn't use 4558 in a boom-box... The JRC datasheet says all - it is based on the grandfather 741 OpAmp: Quote:
#7 | |
The 5532 sounds pretty awful also but not as bad as the generic 4558. Maybe a NJM2068 would work?
What the other guy said----Standing on the shoulders of giants. New avatar- no more little array
#8 |
I've replaced those chips with NJM4580s (same brand as your current NJM4558s) since they are also bipolar input op-amps and they are cheap as well. Try them and you'll notice a big difference and most likely you won't have to modify the existing circuit.
On the other hand you may try space age op-amps as well but I suggest trying those first. A good idea is to install sockets and try different op-amps, then just go with what your ears tell you. |
#9 |
I have tried in my gear NJM2068 and are pretty good too... I just liked (way) better LM4562 in my application (DAC I/V and filtering)
![]() Now, I have LM4562 in all my audio - even where I had SMD OpAmps. Last edited by SoNic_real_one; 11th April 2010 at 02:05 PM. |
| help with replacement tweeter replacement - KLH twenty three | indianajo | Multi-Way | 2 | 15th February 2010 12:54 AM |
| Replacement Diodes | mudihan | Parts | 10 | 22nd September 2009 03:13 AM |
| OP_AMP...replacement...? | Lyra | Car Audio | 5 | 22nd April 2006 07:24 AM |
| Replacement driver | Kittle | Multi-Way | 1 | 7th March 2006 05:51 PM |
| NJM4560 replacement | ragus | Solid State | 3 | 8th March 2004 03:11 PM |
