Proper way to get mono?
Old 24th March 2010, 11:26 AM   #1
pinobot is offline pinobot  Netherlands
Default Proper way to get mono?
Is there a right way to play a stereo signal over one speaker?
Is there any hardware that does this?
I can imagine that simply summing the signals doesn't lead to a very accurate reproduction or does it?
Old 24th March 2010, 01:12 PM   #2
TheSeekerr is offline TheSeekerr  Australia
Summing the signals is the right way. Do it at the input, not the output!
Quick and dirty method is just to use 2 resistors - about 10K should do it.
Proper way is with a summing amplifier, as linked below - use a value between about 1K and 10K for all the resistors.
Op Amp Summing Amplifier
Old 24th March 2010, 03:16 PM   #3
Speedskater is offline Speedskater  United States
Speedskater's Avatar
Or see this Rane Corp. paper:
Why Not Wye?
Kevin
Old 25th March 2010, 02:38 AM   #4
sumaudioguy is offline sumaudioguy  United States
sumaudioguy's Avatar
The problem with simply hooking left and right together is this, the left channel is left plus mono and the right channel is right plus mono. Adding these directly gives left+mono+mono+right so there are two monos and a left and a right. The result of this is not really what is wanted because if the L and R have any time difference of a particular signal there will be a lot of loss in higher frequencies. The attached file is the way I like to make mono but it is a little over the top for most people. This is made with two all pass filter strings and sounds really good.
Proper way to get mono?Hide this!Advertise here!
difference between mixed mono and summed mono Clipped Car Audio 4 10th October 2007 11:34 AM
Looking for proper transformer. contaxchen Parts 0 15th September 2004 02:38 AM
Proper Grounding Scheme PaulHilgeman Parts 38 14th October 2003 05:00 PM
Dual Mono - Anti Mono Power Supplies pmkap Everything Else 3 16th February 2002 05:10 AM
Copyright ©1999-2017 diyAudio
