Go Back   Home > Forums > Source & Line > Analog Line Level
Old 20th March 2010, 01:07 AM   #11
aparatusonitus's Avatar
No, as long as input is without dc offset.
Non é mai abbastanza...
Old 20th March 2010, 04:42 PM   #12
kp93300 is offline kp93300  Malaysia
I remove the 2sk 170 ,2sj74 and replace with matched set with IDSS of 10 and 10.05 ma.
I rewire the drain source orientation.
The input voltage is + 12.07 V and -12.09 V . The dc offset could be trimmed up to 0.1 to 0.14 V only for both channels ---no change.
BTW, i use LM 313 and 337 as regulators .
The pre runs very well without any undue heat in the regulator or the transisitor. I have left the thing on for 1 to hours without problem.
Do i need to match the BC 550 and 560 ?
I do not own a scope, how to check for oscillation as suggested in one of the previous post?
Thanks to all for the suggestions.
Will do further checking later.
Let me enjoy some music ! I am still very satisfied despite the dc offset.
kp93300
Old 20th March 2010, 09:02 PM   #13
juma is offline juma  Serbia
juma's Avatar
kp93300, you are doing something the wrong way - please check everything carefully,it must be something with wiring or components' values.
BJTs don't have to be matched.
Old 20th March 2010, 09:14 PM   #14
Joachim Gerhard's Avatar
Interchanging drain and source with 2SK170 and 2SJ74 is posible without problem.
Try to trimm R6, R7.
Old 21st March 2010, 10:01 AM   #15
PHEONIX is offline PHEONIX  Australia
Originally Posted by kp93300 View Post
I build this circuit contributed by a fellow forum member.
I am unable to trim the dc offset to zero.
Both channels show 0.1 V dc output.
It sound very good with a output cap .
What is the solution?
Do i need to match the vgs ? can a 50R trimmer solve the problem and change the sound character?
kp93300
Why is dc voltage of 0.1V a problem , is this stage going into a power amp.
AR
Old 21st March 2010, 10:44 AM   #16
this schematic is very similar to Pass' F5.
Read that pdf for some clues on setting up.
regards Andrew T.
Old 21st March 2010, 02:37 PM   #17
Bonsai is offline Bonsai  Taiwan
I doubt that changing the pot from 20 to 50 Ohm will 'ruin the sound' of this pre-amp.
bonsai
http://www.hifisonix.com/
offset problem intense-tavda Solid State 6 22nd June 2009 08:24 AM
Simple DC offset question robmil Solid State 7 23rd August 2008 11:19 AM
DC offset problem mravlcax Chip Amps 21 30th April 2008 10:08 AM
Another Offset problem... rtate Solid State 6 19th March 2008 11:03 AM
A40 offset problem? stickleda Pass Labs 8 1st May 2005 12:56 AM
Page generated in 0.10082 seconds (73.70% PHP - 26.30% MySQL) with 11 queries
