Burr-Brown DRV134 AUDIO BALANCED LINE Receiver schematic PCB/Kit anybody?
Old 18th March 2010, 11:41 PM   #1
cirrus18 is offline cirrus18  United Kingdom
Default Burr-Brown DRV134 AUDIO BALANCED LINE Receiver schematic PCB/Kit anybody?
I want to make a Balanced Line RECEIVER using the DRV134. Could anybody kindly help me with any practical information to allow me to do this. Many thanks.
Old 19th March 2010, 12:49 AM   #2
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Do you not mean INA134 ? That's a receiver part which complements the DRV134 balanced line transmitter.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 19th March 2010, 05:37 AM   #3
stratus46 is offline stratus46  United States
That's a simple enough project you might want to tackle it yourself. Jameco electronics sends periodic info and the latest included a Youtube video of Collin Cunningham showing how to make a printed circuit at home - so Jameco can sell you the kits.
Search Youtube Collin Cunningham Circuit Skills: Circuit Board Etching (9:16) and give it a look.
You might also want to check the Analog Devices SSM2143 data sheet as well which is pin compatible.
G
Old 21st March 2010, 11:08 AM   #4
Many thanks for the replies guys. Didn't realise the integrated circuit I wanted was the INA134.
Looking at the INA134s schematic it looks a very simple job. As far as I can see all that one needs is a power supply,,, a couple of capacitors and that's it. It's already to go?.
I would be interested to know from anybody who has had practical experience with the INA134 is my above assumption true, or do I need something else?
Old 21st March 2010, 11:35 AM   #5
PMA is offline PMA  Europe
PMA's Avatar
You need nothing very special, just read the datasheet carefully. I worked with both INA134 and INA217.
http://focus.ti.com/lit/ds/symlink/ina134.pdf
Old 22nd March 2010, 05:24 PM   #6
I've worked with the Analog Devices equivalent and it is as easy as it appears.
The only 'gotcha' is the device is unity gain meaning 1Vp-p at the inputs - remember that is 1/2 Vp-p on either input - will result in 1Vp-p at the output so it may be a small problem if you run very high balanced line levels. The Analog Devices chips are available as unity gain or a -6dB versions which is why I suggest you check their datasheet as well.
Of course you can add resistors in front of the chip to reduce the level by 6dB but the Common Mode Rejection Ratio (CMRR) depends on the precision of the matching of values.
G
Old 22nd March 2010, 09:39 PM   #7
As you suggest I have been reading the data sheet carefully and as I haven't had any experience in reading data sheets before, so I don't quite know what I am looking for.
I intend to make 6 of these receivers to connect the six balanced outputs from my DCX2496 to my six amplifiers phono inputs.
Here is the schematic from the data sheet.......
[IMG]Click the image to open in full size.[/IMG]
Does anyone know if this is an exact practical working configuration ie all I have to do is follow the wiring diagram exactly, provide power, connect the inputs to my DCX2496 digital crossover and the outputs to my power amplifier and I then have a complete receiver up and running. No other parts or wiring needed?
It does show 2x 1 mfd capacitors connected to the power + - supply. It doesn't show that they are electrolytic so what type of capacitor should they be?
Also,where does the 0 volt centre of the -+ connect to.
Any help you can give me would be greatly appreciated.
Old 22nd March 2010, 10:38 PM   #8
That will work but you want those capacitors very close the chip. It's also preferable to use a ground plane to keep impedances down. If you CAN'T use the ground plane you want a wide ground trace for the same reason.
G
Old 23rd March 2010, 01:25 AM   #9
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
G
Are you not aware of the INA137?
Audio Amplifiers - Line Drivers / Receivers - INA137 - TI.com
Old 23rd March 2010, 04:40 AM   #10
Originally Posted by theAnonymous1 View Post
No I wasn't. When I was doing commercial design, I mostly used Analog Devices, a few Burr-Browns, Elantecs and Maxims. A-D will sell you selected higher performance if you want/need it and they never failed to work as described.
G
Burr-Brown DRV134 AUDIO BALANCED LINE Receiver schematic PCB/Kit anybody?Hide this!Advertise here!
Balanced line driver (DRV134) and noise ettos Analog Line Level 34 16th October 2011 11:20 PM
Group Buy: DRV134 pcb, unbalanced to balanced peranders Group Buys 84 11th January 2011 12:01 AM
Discrete balanced line receiver 00940 Solid State 2 31st August 2009 09:51 AM
Cable for audio balanced line driver (drv134 ) fluc Solid State 3 25th April 2008 06:30 PM
is DRV134 the best balanced line driver? anli Chip Amps 4 13th December 2004 06:55 PM
Copyright ©1999-2017 diyAudio
