| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
So , I have some VU-meters left over from an old Midas console. There are actually two types: one is the original with a large white 4"x3" scale ranging from -20 to +3 (usually standard on all VU's), and below the scale it says "ÖVU=1·228V=7500Ω.@1000~".
The other one is a replacement VU with a smaller black 2.5" x 2.5" scale ranging from -20 to +5 (?), nothing printed below that, and on the back are 4 (I'd say germanium) diodes in a rectifying bridge configuration. Now, how do I / should I connect these in order to build a nice 2-channel VU-meter with balanced in/out connectors in order to monitor the input level of an old Quad-Eight (Q8) preamp that lacks of VU's? I imagine that I have to build a special circuit for that. Any hints on some schematics would be great. Thanks in advance, Phantombox |
#2 | |
In broadcast in the US it's very common to have the '0' reference operating level at +4 dBu, AKA 1.228 V rms. It's been a LONG time since I saw any broadcst facility actually terminate their 600 lines at 600 ohms which would be +4dBm. In my opinion VU meters with 23dB scale range are pretty much useless for setting anything other than continuous tones. With analog tape machines it takes quite a while to realize that jingling a ring of keys in front of the mic should be set at -15 to -20 because the ballistics of the meter will not show you the peaks which in fact are up near 0. Peak reading meters with controlled decay are more suitable for actual audio. G² |
#3 |
Interesting, I just picked up a really nice pair of VU meters that were on special at a local electronics shop. I plan to do this project with mine (link below).
Project 128 I use a fair few ESP boards and actually have one of his balanced receiver boards handy. Will let you know how I go. col.
http://www.minirig.org.au |
#4 | |
VU meter - Wikipedia, the free encyclopedia "A VU meter is often included in audio equipment to display a signal level in Volume Units; the device is sometimes also called volume indicator (VI). It is intentionally a "slow" measurement, averaging out peaks and troughs of short duration to reflect the perceived loudness of the material." A VU is usually a little better at showing relitive RMS power levels (highly influenced by program material) but niether VU or peak meters are true power meters. I think a VU meter is what you want for pre amp input, although with the way most music these days is limited to near death a peak and a VU will look almost identical. |
#5 | |
Check out the metering in Adobe Audition. That's how it should be done. Even a second grader can get that right. G² |
#6 |
I have these, wired with an Alps Pot...I can just set them to whatever level that I am listening to...And they work Great...Still have to find that Nice cigar box to put them in...
DIY Dancing Needle Box |
#7 | |
#8 |
wow.. those Dorrough meters are really nice. I like the demo on the home page too, if gives a good example of how to read the levels in relation to the music being played. Feel inspired to get cracking on my VU project now.
col :-)
#9 | |
#10 | |
Don't believe me? Get a scope on your VU meter equipped gear and set a test tone to 0 on the meter and 6 divisions on the scope. Now change the program material to keys jingling (something you can easily do at home), set the peaks to the same level on the scope and check the VU meter. It will be 15 to 20dB low. Worse, some other program material will be much closer to the same. Solo flute or a pipe organ flute stop will be very close meaning you have to 'interpret' the readings. Try all sorts of different program and you'll find it's all over the map. I think true VU meters are close to useless for program audio if you want it right - but the test tones will be perfect. The 46 dB peak reading meters on my old Nakamichi cassette are much better but the 60 dB range peak metering on the Sony digital processor is better yet and the 96dB range in Adobe Audition with lagging peak levels is about as good as it gets meaning it's virtually the same as the scope all the time. In fact it's better than the scope as you might have blinked and missed a peak but the lagging peak reading will catch it. Broadcast machines have had peak meters (sometimes selectable peak / VU) for 30 years. Any place I've worked with switchable meters have ALWAYS been set to peak. G² |
| VU-meter | cristelu2006 | Equipment & Tools | 2 | 6th December 2009 12:18 PM |
| vu meter | surfstu | Tubes / Valves | 14 | 24th March 2009 10:03 PM |
| t-amp vu meter and volt meter question.... | rectaacies | Class D | 7 | 3rd February 2006 12:22 PM |
| VU meter | nbcd | Solid State | 5 | 16th November 2003 10:02 PM |
| Page generated in 0.17923 seconds (74.05% PHP - 25.95% MySQL) with 11 queries |
