| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 |
This is how 1mA meters work when run thru a 10k Alps from the Speaker Posts..
YouTube - Too Old2.mp4 |
#12 |
From a discrete PPM (Peak Program Meter) built to BBC standards with a Dolby B processor on my Revox 15" dual track.
1970's - thank you Wireless World! These have special ballistics which are critically damped and have to be driven with a fast rise-time / slow fall-time meter driver. I don'r suppose I shall ever get round to using these again - are they worth anything to anyone? Cliff |
#13 |
Now I built a circuit based on the ESP project 128. Instead of 2 TL072's I use 1 TL074, and as power supply I use a regulated single rail unit with virtual ground and set it at +24V (+12/-12V). In theory, voltage should not affect the output signal but it does. The higher I set the total voltage the more does the needle swing. I'm almost certain that I made a mistake but cannot figure out where it is.
My last project was a PIAA phono preamp with a TL074 and a 12V wallwart and virtual ground and it works just fine, so I think the PS is OK. Any suggestions? |
#14 |
#15 |
Here's the schematic of the VU driver: Project 128 (figures 3 and 4. See the 2nd reply to my post by Col from AustrAlia) and here is my power supply: http://kitsrus.com/pdf/k124.pdf (end of page 2, acts s a "wall wart"), followed by a dividing circuit with two 220uF capacitors and two 4.7k resistors (that's the virtual ground).
| VU-meter | cristelu2006 | Equipment & Tools | 2 | 6th December 2009 11:18 AM |
| vu meter | surfstu | Tubes / Valves | 14 | 24th March 2009 09:03 PM |
| t-amp vu meter and volt meter question.... | rectaacies | Class D | 7 | 3rd February 2006 11:22 AM |
| VU meter | nbcd | Solid State | 5 | 16th November 2003 09:02 PM |
| Page generated in 0.07540 seconds (73.87% PHP - 26.13% MySQL) with 11 queries |
