| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#21 |
Thanks for all the suggestions. I have subsequently found many other phono projects here, as well as requests/questions similar to my own; my early searches were limited to "Analogue Line" section. I thought it was curious how few threads I was finding on phono preamps....
Thanks again!
Shaun Onverwacht |||||||||| DON'T PANIC |||||||||| |
#22 |
Shaun, I have a project with me that I've been using for quite some time. its really good and not overly complicated. Only problem is it is a scan from a magazine (Elektor India 1991) and the pdf file size is more 6mb. Maybe I could mail it to you if you like.
Hari |
#23 |
Managed to re-draw the schematic. Here is the pdf file.
#24 |
Hi Jethari
Thanks for sharing that. It is indeed uncomplicated.
#25 |
It is a very good circuit. I've been using it for some time now along with the Quasi NMOS power amp. The only change from the original schematic is C2 which I changed from 150n to 100n as I was not too happy with the bass.
Hari |
#26 |
Here's the pcb layout I've used for the phono pre.
Hari |
| Good Phono preamp circuit? | PeterMoreton | Solid State | 45 | 30th November 2011 11:49 AM |
| new phono stage or old preamp with phono? | flohmann | Analog Line Level | 2 | 2nd October 2008 09:51 PM |
| Electret mic preamp - will phono preamp work? | darthmullet | Analogue Source | 6 | 12th October 2007 07:32 AM |
| Hum in phono circuit | Bama Slamma | Solid State | 2 | 17th March 2007 03:25 AM |
| simple phono preamp circuit needed | needtubes | Tubes / Valves | 4 | 3rd July 2004 08:27 PM |
| Page generated in 0.07409 seconds (76.51% PHP - 23.49% MySQL) with 11 queries |
