Go Back   Home > Forums > Source & Line > Analog Line Level
Old 30th March 2010, 04:20 PM   #21
cbdb is offline cbdb  Canada
ou say the charge builds up between the RCA shield and chassis
The shield needs to be grounded at least at one end, are the chassis not grounded, (2 pin power)?
Did the hot and neutral of your power get swapped? (meter them to ground) is there any DC on your 120V power.
(aside: the power in a house here and in the US is two legs off a three phase distribution transformer so the two hots are 120 degrees out of phase and thats why you only get 220v not 240V between them)
Old 30th March 2010, 05:33 PM   #22
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
DC on mains is not the case; if so, the xformer would have been burned. At any rate, DC doesn't go through a xformer last time I looked.
Also don't see any connection between swapping mains pins and gradual buildup of whatever on the chassis. What's your reasoning here?
Do the simple things first. If there's a potential difference between shield and chassis, connect them with a wire. That should be interesting.
Dead giveaway: what was the common piece of equipment with all those different configs that had the problem? If there is a problem at all.
jd
/Another new issue: Linear Audio Volume 3!
Why collector/drain output stages are so rare??? Leolabs Solid State 67 3rd September 2011 09:37 AM
Best voltage reference device for a cascode BJT CCS? ray_moth Tubes / Valves 2 1st July 2009 09:38 PM
snake cable - drain wire connects to..?? redrabbit Parts 5 9th August 2006 04:42 AM
single stage common-drain amplifier Music_Sg Solid State 4 4th July 2006 05:45 PM
PSpice modeling, MOSFET, Turn-on Charge, Reverse drain current naula Parts 0 21st January 2003 02:00 PM
Page generated in 0.07014 seconds (63.74% PHP - 36.26% MySQL) with 10 queries
