Go Back   Home > Forums > Source & Line > Analog Line Level
Old 8th March 2010, 08:17 PM   #1
Jimmy154's Avatar
Default Subsonic filter options
Here are links to three different subsonic filters:
SUBSONIC FILTER - Circuit Diagram - Forum - SeekIC.com
Subsonic / Rumble Filter for Phono preamps and Sub-Woofers
Subsonic Filter
I would want for the -3 db point to start at around 18 Hz, I think, and I'm not sure the last one does. But then again the last one does say that it operates between 12-15 Volts, are they all like this? It is important to me since I will want to wire this probably where my head unit is in my car. Will the "safety" resistor the second link recommends be sufficient to send the right amount of current to this circuit? Also I looked on digikey.com (not sure if this is the best place to get these parts) and they had 113 different kinds of TL082 OP amps and I don't know which one to get. Now that I think about it I don't know what resistors or capacitors to get either lol
If the second one can run from 12-15 Volts I would like to make that one, I suppose. Only thing I don't know is what the downward "hashed" arrow means under the 100k resistor. I think it means ground, but the circuit already has a ground, so I guess it's meant to be grounded to something else?
We do not allow political statements or conjecture to be made on these forums.---the diyAudio moderation team
Old 8th March 2010, 08:36 PM   #2
Did it Himself
richie00boy's Avatar
Unfortunately none of those are suitable for a car as they all require split supplies.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 8th March 2010, 10:00 PM   #3
Jimmy154's Avatar
I have been trying to figure out what a split supply for the past hour, but it's not going well for me.
Is there anything that will work that I can do myself? I have noticed that Fmod sells some subsonic filters that plug into RCAs, can I make ones like this myself?
Guess I found it: http://www.t-linespeakers.org/tech/f...ssiveHLxo.html
Looks like it won't achieve the slopes I was looking for though (24-48 db/octave).
Old 8th March 2010, 10:40 PM   #4
Jimmy154's Avatar
In the link http://www.t-linespeakers.org/tech/f...ssiveHLxo.html what does "W" mean in: "Select a value for R1 (around 5-10 k W should work well with most amps), . . ." Is it a resistor of 5-10k ohm rated for one Watt?
Does any one know how I can determine what the input impedance of my amplifier is?
Old 8th March 2010, 10:56 PM   #5
roger_lew's Avatar
I think "W" = "ohm" in this case.
Keep in mind with PLLXO you attenuate your line signal. Whether that is a problem or not depends on your setup of course.
Roger
Old 8th March 2010, 11:01 PM   #6
Jimmy154's Avatar
The attenuation is only a problem if it is too great. However, I don't know how great it will be lol
Old 8th March 2010, 11:18 PM   #7
Artie is offline Artie  United States
I don't know if this will help your situation, but its worth a mention. The TC962 chip, from Microchip, will create a +/- supply from a single supply. Yamaha uses it in one of their bass guitars to get +/- 9volts from a single 9-volt battery. You could use it to create your bipolar supply.
website
TC962.pdf
Note: The above schematic is derived from the Yamaha schematic which actually uses the older version chip. (TC7662, or some-such.)
Old 9th March 2010, 12:18 AM   #8
Jimmy154's Avatar
I don't know enough about electronics to know if that Yamaha schematic would work the way it is at 12-15V. I actually don't even know why I need it, to create a split supply whatever that is, right?
The 12 db/octave passive low level cross-over looks like a simpler (but less effective) solution, if only I knew what my amps input impedance is or how to measure it.
Old 9th March 2010, 02:25 PM   #9
Jimmy154's Avatar
To summarize, I would like to build this subsonic filter, for my friend's car: Subsonic / Rumble Filter for Phono preamps and Sub-Woofers or a similar one. But I don't know what if the circuit two posts above is all I need to make this work. The input voltage would be 12-15 volts from the car battery. I would just tap the radio (head unit) power supply, I suppose. Will this work?
I can read most schematics, but that's about it. My knowledge of electronics is fairly limited, as you probably can tell. I think I could make this work with some help, but should I just give up and go with the simpler passive low level subsonic filter?
Old 9th March 2010, 06:53 PM   #10
Did it Himself
A split supply is one that has positive and negative power rails as well as ground/0V. You could look at project95 on the ESP website.
Volume control + subsonic filter Buzzy Parts 5 19th June 2009 05:37 AM
Subsonic filter bybass? jakelm3075 Subwoofers 14 16th March 2006 02:55 PM
Is it possible: passive subsonic filter? Geez Subwoofers 7 9th August 2005 06:50 AM
DIY subsonic filter anyone? BobM Analogue Source 4 25th August 2003 06:21 PM
Subsonic filter for a SubWoofer guylemar Subwoofers 10 28th March 2003 02:38 AM
Page generated in 0.11046 seconds (80.65% PHP - 19.35% MySQL) with 10 queries
