Go Back   Home > Forums > Source & Line > Analog Line Level
Old 11th March 2010, 11:21 PM   #21
Jimmy154's Avatar
Got confused again
Is the crossover down 3 db or 6 at f? Using these equations: Passive Line-Level Crossover
We do not allow political statements or conjecture to be made on these forums.---the diyAudio moderation team
Old 12th March 2010, 12:09 AM   #22
Jimmy154's Avatar
Looks like R2 (with the vertical line above it) has to be positive for the circuit to function properly, but it is recommended that I use 5K-10K resistor for the 12 db/octave slope. All values above 1K ohm for R1 will cause R2 (with the vertical line above it) to be negative, since my amp input impedance is 10K ohm. What do I do? Here is the link to the formulas: Passive Line-Level Crossover
Looks like my only option is to choose a R1 resistor lower than 1K ohm, correct?
Old 12th March 2010, 02:05 PM   #23
Jimmy154's Avatar
Can I use the amp input impedance as the R2 resistance without using a resistor?
Values would be:
R1=1k ohm
R2 or amp's input impedance=10k ohm
C1=1.06e-5 F
C2=1.06e-6 F
or should I use?:
R1=500 ohm
R2=5k ohm
C1=2.12e-5 F
C2=2.12e-6 F
R2(with line over the 2)=10k ohm
Or should I use other values? It's a 12 db/octave high pass filter at 15 Hz.
Old 13th March 2010, 11:18 PM   #24
Jimmy154's Avatar
I can see I have ostracized myself from the diyaudio community, possibly due to my signature.
I'm gonna have to go it alone. Wish me luck friends (and enemies).
Old 15th March 2010, 11:36 PM   #25
Artie is offline Artie  United States
Which BA amp do you, (or your friend), have? Don't the Bostons already have a built-in x-over / filter?
Old 16th March 2010, 12:35 AM   #26
Jimmy154's Avatar
I have the GT-28. It does not have a subsonic filter. Although I do believe it might come with some sort of optional subwoofer control module that I do not have.
I'm going with these values:
R1=1k ohm
R2 or amp's input impedance only=10k ohm
C1=11.6 uF
C2=1.1 uF
Hopefully, as I understand it, this will give me -6 db at 14.5 Hz.
Old 16th March 2010, 01:06 AM   #27
Those numbers look good, except that you'll have -12db at your "f" value. But thats good in my book. Try it and see.
Old 16th March 2010, 01:40 AM   #28
Jimmy154's Avatar
Hmm . . . I was hoping for -6 db at 14.5 because my friend's subwoofers are tuned to 18 Hz roughly. Is it a problem that I used only the amp's input impedance as the R2 resistance or impedance?
I thought 12 db/octave Linkwitz-Riley were down 6 db at "f":
http://www.bcae1.com/images/gifs/xo2ndlra.gif
Old 16th March 2010, 09:19 AM   #29
I'm not sure. Someone more knowledgeable than me will have to field that one. It sounds feasible though.
I was just going by the fact that its called a 12db/octave curve. It may well start at -6db.
Volume control + subsonic filter Buzzy Parts 5 19th June 2009 04:37 AM
Subsonic filter bybass? jakelm3075 Subwoofers 14 16th March 2006 01:55 PM
Is it possible: passive subsonic filter? Geez Subwoofers 7 9th August 2005 05:50 AM
DIY subsonic filter anyone? BobM Analogue Source 4 25th August 2003 05:21 PM
Subsonic filter for a SubWoofer guylemar Subwoofers 10 28th March 2003 01:38 AM
Page generated in 0.09416 seconds (76.87% PHP - 23.13% MySQL) with 10 queries
