Go Back   Home > Forums > Source & Line > Analog Line Level
Old 9th March 2010, 07:28 PM   #11
Jimmy154's Avatar
Originally Posted by richie00boy View Post
A split supply is one that has positive and negative power rails as well as ground/0V. You could look at project95 on the ESP website.
Can I use this split power supply in it's current configuration and values with a 12-15V car power supply?:
We do not allow political statements or conjecture to be made on these forums.---the diyAudio moderation team
Old 9th March 2010, 08:03 PM   #12
Artie is offline Artie  United States
The chip data sheet says its good up to 18-volt output, but you'ld need to up a couple of those cap values. Honestly, I don't think I'd mess with this method if you don't have a little more electronics experience. I haven't even tried it myself yet.
If you can live with a simple 1st order filter, why not just do as they show here:High-pass filter - Wikipedia, the free encyclopedia
That will give you -6db / oct.
Old 9th March 2010, 11:51 PM   #13
Jimmy154's Avatar
Yes, I read the chip specs, that it had an output of 3-18V. I thought, with my limited electrical knowledge, that I need higher Cap values for higher output, but didn't know what value and what else needed to be changed.
I guess I will go with this 12 db/octave filter: Passive Line-Level Crossover once I figure out my amp's input impedance. I am waiting from a response from Boston Acoustics, since I don't know of an easy way to measure this spec.
Old 10th March 2010, 02:49 AM   #14
Jimmy154's Avatar
Can I adjust the Q of the passive line level crossovers to a Q of 1 or more? Change the equations a little perhaps?
Old 10th March 2010, 03:28 AM   #15
Jimmy154's Avatar
Project95 creates a -12V and ground and the +12V input to this circuit would also act as an input to the project99 circuit? Then all I would have to do is limit the current to this circuit (or both circuits?) from my car wiring with some resistor(s)?
Old 10th March 2010, 07:24 PM   #16
Did it Himself
richie00boy's Avatar
No just build P95 and P99 as they are. You would do well to read some of the basics on the ESP site as well.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 10th March 2010, 07:56 PM   #17
Jimmy154's Avatar
I will try for the active filter if my friend really wants that option. Does any one know how to tweak the passive filter so the Q is 1 or higher?
Old 10th March 2010, 08:33 PM   #18
Did it Himself
You can't get high Q with a passive filter unless you go to using inductors as well which I think is beyond your level.
Old 11th March 2010, 03:30 PM   #19
Jimmy154's Avatar
I just realized I don't know what kind of capacitors or resistors to use in this circuit: Passive Line-Level Crossover
Old 11th March 2010, 11:30 PM   #20
Jimmy154's Avatar
I just realized I could probably look that up
Volume control + subsonic filter Buzzy Parts 5 19th June 2009 05:37 AM
Subsonic filter bybass? jakelm3075 Subwoofers 14 16th March 2006 02:55 PM
Is it possible: passive subsonic filter? Geez Subwoofers 7 9th August 2005 06:50 AM
DIY subsonic filter anyone? BobM Analogue Source 4 25th August 2003 06:21 PM
Subsonic filter for a SubWoofer guylemar Subwoofers 10 28th March 2003 02:38 AM
Page generated in 0.12002 seconds (80.14% PHP - 19.86% MySQL) with 10 queries
