Go Back   Home > Forums > Source & Line > Analog Line Level
Old 3rd March 2010, 09:49 AM   #1
Default why there is a spike sound output from the speaker when turn off?
hi,
i'm using a DIY pre-amp kit with 3-way tone control and also a power amplifier. then i connect the final output to a speaker. Whenever i turn off the switch, i can hear a "spike" sound coming out from the speaker. How can i solve this problem?
thank you.
Old 4th March 2010, 01:39 AM   #2
anyone can help?
thanks.
Old 4th March 2010, 01:48 AM   #3
When you open the power switch the field collapses in the power transformer core generating a large inductive voltage spike on the windings that often causes a bit of arcing and a nice jolt of noise through any amplifiers that are still active. If you get lucky enough to open the switch the moment the AC line crosses zero everything turns off in a much better behaved fashion than when the voltage is at peak.
Old 4th March 2010, 02:48 AM   #4
Spark coil effect.
Old 4th March 2010, 05:42 AM   #5
wwenze is offline wwenze  Singapore
O.o .........
Threadstarter do you mean pop? Or like "piak piak" kind of sound? Usually happens a few seconds after cutting the power?
Old 5th March 2010, 09:48 PM   #6
indianajo's Avatar
Default turnoff suppressor
I got annoyed at the the click when I turn off my 1972 manufactured ST 120 amp. I salvaged out a dead PC power supply, in it were several MOS suppressors. They are not marked with a part number, but they are marked with the UL and CSA logos, and look like blue disks. They can be found near the power fuse. I put it across the primary of my power transformer, near the power switch. I installed a terminal strip so that I would not have to solder directly to the power strip nor have these short lead devices dangling in the air with exposed leads. The snap at turnoff has been much reduced. If you live in a 250 VAC mains area, make sure the logo of you local standards agency is on the part. For example, I think Europe uses VDO, all though I am not an expert on that. A .47 uf capacitor will also help reduce noise, if certified for installation across the power mains it will also have these rating agency logos on it.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,SP2-XT's, T-300 HF Projs, Steinway console, Herald RA88a mixer, Wurlitzer 4500
Old 8th March 2010, 04:26 AM   #7
Originally Posted by wwenze View Post
O.o .........
is a POP sound. happen once i turn off the main power.
Old 10th March 2010, 06:17 AM   #8
ratza is offline ratza  Romania
ratza's Avatar
2n2/1kV capacitor across power switch and RF filtering on inputs will do the job.
Any solution is a compromise.
Popping sound after turn off? portreathbeach Chip Amps 20 1st March 2010 09:43 PM
spike from SG3525 jegandren Power Supplies 7 13th September 2008 04:23 PM
BOZ - DC at the output at turn on bugg Pass Labs 11 25th August 2005 06:08 PM
Speaker Spike bjackson Multi-Way 8 9th May 2005 02:12 AM
popping sound when I turn my radio off feelinhipp Car Audio 2 20th April 2004 03:38 AM
Page generated in 0.10325 seconds (74.28% PHP - 25.72% MySQL) with 10 queries
