Go Back   Home > Forums > Source & Line > Analog Line Level
Old 6th January 2011, 06:37 PM   #21
leoduran's Avatar
Default Single-ended (RCA) input (AUX2)
Old 6th January 2011, 11:57 PM   #22
Speedskater's Avatar
When you re-drew the schematics, why didn't you correct the XLR pin #1 errors?
Kevin
Old 7th January 2011, 01:14 AM   #23
leoduran's Avatar
Default Ummh...
Kevin,
I'm not sure I understand the "XLR Pin1" errors you're referring to.
Here's my intention (and hopefully the drawings reflect that):
1. Pin1 of inputs are tied together.
2. Pin1 of outputs are tied together.
3. Pin1 of outputs are ALWAYS tied to "Chassis Gnd".
4. Pin1 of inputs are conditionally tied to Pin1 of outputs.
That is, the DPDT-CO "LIFT" switch provides the option to:
(a) leave Pin1 of inputs floating (thus the name "LIFT")
(b) tie Pin1 of inputs directly to Pin1 of outputs (Hard Gnd)
(c) tie Pin1 of inputs via 1.5 resistor to Pin1 of outputs (Soft Gnd)
5. Pin1 of outputs is connected to Pin3 of outputs for single-ended ("RCA") output mode, as selected by the DPDT XLR/RCA switch.
6. And, lastly, for the single-ended (RCA) input case (AUX2 in the revised schematic), RCA common/ground of that input is connected to Pin1 of other input XLR's, and potentially to Pin1 of outputs (and "Chassis Gnd"), via the the LIFT switch.
Can you please explain what I missed?
Thanks.
Last edited by leoduran; 7th January 2011 at 01:28 AM. Reason: added comment about AUX2 for single-ended (RCA) case
Old 13th January 2011, 02:11 AM   #24
XLR pins #1 should:
a] Be connected directly to the chassis as near as practicable to the connector.
b] Should NOT be connected to other connectors or other components (switches & resistors).
c] Should NOT be part of the audio circuit.
Kevin
Old 13th January 2011, 03:13 AM   #25
What I would do is:
a] Eliminate all the lift switches, all the 1.5K resistors and all the RCA phono connectors.
b] Correctly wire the XLR pins #1.
c] Modify balanced interconnects to gain the other features.
That is if you need an unbalanced input or output, put the correct connector on the far end of a balanced interconnect.
If you really want to dis-connect a balanced shield do it inside the cable connector.
Kevin
Old 13th January 2011, 06:30 PM   #26
leoduran's Avatar
Default To the "XLR Pin1 police"...
What I would do is:
OK, as revised, I did tie all pin1 inputs together, and removed LIFT switches, except for one (which does allow for tying pin1 of the outputs to the inputs; while providing the option to float the inputs... just my preference!).
Ummh... I do need unbalanced/RCA outputs, so if I used a converter cable (as you suggest), what would that cable do?: (1) tie XLR-pin2 to RCA-signal (2) tie XLR-pin3 & pin1 to RCA-common... which should be effectively what I've accomplished by having RCA outputs, coupled with the RCA/XLR switch (so, I chose to leave that as-is).
BTW, I've made all the changes (but kept AUX2 with XLR's for now), and it all sounds great!
Thanks for the feedback.
Old 14th January 2011, 12:57 AM   #27
You might read some of Tony Waldron's papers on interconnects and EMI/RFI interference.
Tony Waldron's EMC ranting and ravings
Kevin
Sowter DAC Tranformers Gorm Swap Meet 10 13th January 2010 08:22 PM
2x Sowter 9545z bakus11 Swap Meet 4 16th November 2009 07:13 AM
would like a substitute for Sowter 3575-C 69CamaroSS396 Tubes / Valves 2 20th April 2009 11:14 PM
Sowter 9055 wildmonkeysects Swap Meet 4 1st May 2008 02:30 AM
Sowter 5113 croccodillo Tubes / Valves 0 28th June 2007 12:40 PM
Page generated in 0.10024 seconds (80.47% PHP - 19.53% MySQL) with 10 queries
