| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
This SS Preamp I was made in 1990, full complementary simetry, selektor with releys. Tube preamp was made 5 years after.
#2 |
But what is the question
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
And, more importantly, what is the tube?
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#4 |
I sent unfinished post. Tube is ecc88, work without feedback like Counterpoint SA3.1
Part list: R1,R2-12k 2W R3,R4-220R R5,R6-680R R7,R8-100R R9,R10,R13-1M R11,R12-3M9 R14,R15-10k R16,R17-1k R18,R19-10R R20-680k R21-470R C1,C2,C3,C4-1uF400V MKP C5,C6,C8-22uF/350V C7-47uF/16V C9,C10,C11,C12-47uF/350V C13,C14-1000uF/16V C15-47nF/100V MKS C16-220nF/150V MKS C17-100nF/63V MKS D1,D2-ZF10V D3,D4,D5-1N4148 D6,D7,D8,D9,D10,D11,D12,D13,D14-1N4007 V1-ECC88 Q1,Q2-BC546 Q3-IRF830 IC1-NE555 IC2-7805 LD1-RED LD2-GREEN RE1-5V2X1A AC1-120VAC 100mA AC2-9VAC 1A |
#5 |
Question. Have anyone expirience compering Nelson Pass "Bride of Zen" preamp vs Tube or full symetry SS Preamps? I think to change symetry SS with Nelsons pramp, any sugest?
#6 |
The one and only
IMHO, the BOZ is not quite as good as the more symmetric
SOBOZ, aka the balanced line stage. I think this is simply due to the lower distortion of the push-pull nature of the circuit.
#7 |
What is your opinion about single triode vs single mosfet line preamp ? I dont speak English, but hope you understand me.
#8 |
Nelson may disagree, but the newest crop of, gasp, Op-Amps are so stinking good that it kind of closes the preamp arguments. Of course, the same care must be exercised in the power, ground, and layout as any high performance analog circuit. No tube circuit can be anywhere as clean. My opinion, my ears and my speakers. Your milage may vary. ( I still play with tubes, they are fun, but can't match ss)
#9 |
Official Court Jester
if I may chip in ..........
that question is .... different horses for courses ![]() off course - you know that stage can be evaluated only in conjunction with his own power supply ; few thoughts : your tube line stage have one serious flaw - too much gain , at least if it's intended for use in modern audio chain , where almost every CD player is capable ( at least voltage vise ) to directly feed usual power amp . local degeneration is way to tame excessive gain ...... even if some ppl are against it ...... Papa's BOZ was sort of student's project ; nice example and chance for every young diy-er to make something different and fresh ; but - it's not flawless either - PS is generic , with too much noise for serious biz ...... stage is somewhat prone to easy overdrive with modern sources etc. so - conclusion - I think that simple ( but well thought ) tube stage , with decent PS is one range better than similar mosfet stage ( also with decent PS) . if we use some older - so called audio signal mosfets .... 2SK216 for instance , maybe we can gain better results ; there is place for some local degeneration ..... CCS loading ....... choke , or even xformer loading ..... sky is da limit , if we wanna play ..... but - if you want ultimate results , you must reach for some more complicated rabbits from hat
my Papa is smarter than your Nelson ! tnx to |
#10 | |
anyway - give me anything else , but OP no ......... high S inductance loaded tube stage is hard to beat ; as always - YMMMV
| SS Preamp and Tube Poweramp | Diogrus | Tubes / Valves | 0 | 10th November 2007 01:02 AM |
| SS preamp w/ tube amp | awhite1159 | Tubes / Valves | 10 | 2nd September 2007 12:55 PM |
| tube preamp + SS power amp. | yngwie | Tubes / Valves | 8 | 27th April 2007 02:55 AM |
| Gabevee's SS tube-like preamp | needtubes | Solid State | 24 | 27th April 2006 10:13 AM |
| tube/ss hybrid mic preamp help! | mwmitchell | Solid State | 0 | 4th August 2002 02:11 PM |
| Page generated in 0.12417 seconds (73.32% PHP - 26.68% MySQL) with 11 queries |
