Capacitor Across Power Switch to Control Switch On Noise? - Page 3 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 21st April 2013, 02:58 PM   #21
DF96 is offline DF96  England
Yes, the load side is correct. However, a cap on the supply side of the switch will not draw much power unless it has a poor dielectric. It will draw current, but as this is in quadrature with the voltage it does not represent net power flow.
Incidentally, the thread was about power-on noise. Caps around the switch reduce power-off noise. They will only affect power-on noise if the switch suffers from bad bouncing.
switch noise kffern Analog Line Level 2 22nd February 2009 12:21 AM
Eliminate influence of switching noise from light switch in to power supply artquake Power Supplies 34 20th October 2008 05:09 PM
Never try to switch 450V DC at 3A with a conventional mains switch... Eva Power Supplies 28 1st November 2006 09:24 AM
Switch noise peace brainerd Parts 19 15th January 2006 10:53 PM
Using a momentary switch for main power switch? FullThrottleRic Parts 9 25th June 2002 08:23 PM
Copyright 1999-2017 diyAudio
