Go Back   Home > Forums > Source & Line > Analog Line Level
Old 11th February 2010, 07:05 AM   #21
Mooly's Avatar
You need to see if there is any DC voltage on the output of the second OpAmps. If yes and it's more than a say 5 mv, the caps should stay.
The "first" 100uf... measure DC volts on it from the DAC.
Changing the 6K8 to 4K7 alters the AC response of that stage due to C352 and C353. You have increased the bandwidth... letting more HF "hash" through.
A simulation free zone. Design it, build it, test it.
Old 11th February 2010, 07:24 AM   #22
Oystein is offline Oystein  Netherlands
I can understand I need some dc protection but only 1 set of capacitors should do fine ...
If I keep the set after the amplification it doen not matter that much if the is a little (amplified) dc voltage in front of it.
The first stage has little amplification so any present dc from the dac will be small.
Old 11th February 2010, 07:33 AM   #23
Mooly's Avatar
The DAC output "may" be at several volts by design... so measure it on the first 100uf cap to be absolutely sure.
The offset voltage of the opamps is an issue as well. With the caps in place there should ideally be zero DC volts at the output of each opamp. FET devices will give this, bjt's won't .
Old 11th February 2010, 07:36 AM   #24
Mooly's Avatar
In fact looking more closely at your circuit pin 13 of the DAC is shown as being at 2.5 volts... but measure it for yourself
Old 11th February 2010, 07:43 AM   #25
You are right ... the center voltage on the analog out is 0.5 * Vcc
I will measure the voltages before I will make any changes.
life lesson on ceramic capacitors in signal path mazurek Parts 11 23rd February 2006 04:00 AM
Good or bad to use parallel capacitors of same value in signal path... 2004ex Tubes / Valves 1 25th May 2005 11:38 AM
Tantalum Capacitors in Signal Path schnullimaus Parts 9 30th April 2005 11:07 AM
How does this sound for a signal path? Fryguy Digital Source 0 25th May 2004 08:15 PM
15uf signal path capacitors for BOSOZ ralf Pass Labs 5 24th April 2002 07:51 PM
Page generated in 0.06876 seconds (80.18% PHP - 19.82% MySQL) with 11 queries
