KENWOOD L-07 CII  preamp
Old 23rd January 2010, 03:12 PM   #1
dray177 is offline dray177  France
Default KENWOOD L-07 CII preamp
It's my first thread here.
I have a Kenwood L-07 CII with a problem on the right input phono MC stage ( noisy with cracking... ).
But without diagram impossible to repair.
And also impossible to find service manual, schematic, information about, ...
Please I need your help !
Raymond
My preamp :
Old 23rd January 2010, 03:56 PM   #2
aparatusonitus is offline aparatusonitus  Croatia
aparatusonitus's Avatar
Hi and wellcome to forum dray177,
I've just being given a schematic for L-07C model, so you can send me a pm via forum with your private email so I can send.
Non mai abbastanza...
Old 23rd January 2010, 04:33 PM   #3
Ooooooooh !!!
Thanks Aparatusonitus for your nice intention.
My address : dray177@aol.com
Raymond
Old 23rd January 2010, 04:53 PM   #4
Check your email ;-)
Old 27th January 2010, 11:50 AM   #5
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
Hallo, Raymond
You still remember to me (Mark Levinson No. 23)?
I have had the complete Service Manual from Kenwood's L-07 CII (original printing, not copy), but until this day I don't find it.
But I recall, that I have order it there:
Schaltungsdienst Lange oHG
Impressum: Schaltungsdienst Lange oHG
Zehrensdorfer Str. 11
12277 Berlin-Marienfelde
Tel.: ++49 (0) 30 / 723 81-3
Fax: ++49 (0) 30 / 723 81-500
info@schaltungsdienst.de
Andreas
P. S.: very fine website:
http://www.wtconcept.com/levinsonml2/
Old 27th January 2010, 01:44 PM   #6
Originally Posted by tiefbassuebertr View Post
Hallo, Raymond
You still remember to me ( Mark Levinson No. 23 )?
Andreas
levinsonml2
Hello Andreas
IMPOSSIBLE !!! I will never forget my best friends
And discuss with you about Levinson gear as ML-1 faulty line modules, ...
What a pity you don't find your SM L-07CII.
Aparatusonitus very kindly ( again many thanks ! ) send me the L-07C schematics.
But a bit very different with MKII model.
And still, I never found these faulty components in the right MC phonostage of my preamp !
In fact, would L-07CII be more difficult to repair than a Levinson ML-2 ???
Raymond
Old 27th January 2010, 07:47 PM   #7
Raymond
No.
.....on the right input phono MC stage ( noisy with cracking... ) ???
At first you must perform a failure isolation.
If there are switches to select the input impedance and gain factor, remove it and solder wires to get the neseccary values (no longer non linear transition resistance there are)
Now check out and compare the behavior with
- open input
- short input and
- normal input connection to your moving coil cartridge.
What happens? Is sound to hear? Or only noisy with cracking (flicker noise, shot noise)? Then there is a complete break in the signal line.
Are there a reaction by a slightly mechanical strain to the j-FET's and BjT arround the MC head amp?
If yes, and there are no bad soldering in this aera, the internal bond wire of the transistor itself has temporary interruption or unwanted transition resistance.
What about the color of the MC head amp transistor pins (black or silver)?
If you try to find schematics by google, uses different spelling
"L 07CII" "L07C II" "L07CII" "L 07C II" "L 07 C II" "L07 C II" both "Trio" and "Kenwood" for second keyword.
Here are some Links:
TRIO ƒRƒ“ƒgƒ[ƒ‹ƒAƒ“ƒvL-07CII‚Žd—l ƒgƒŠƒI
TRIO/KENWOOD ƒZƒpƒŒ[ƒgƒAƒ“ƒv/‚‚‘ƒAƒ“ƒvˆ—— ƒgƒŠƒI/ƒPƒ“ƒEƒbƒh
review33.com - 影Ÿ天œ
Kenwood L-07C-II, Hifi-Klassiker - HIFI-FORUM
and attachements:
Old 27th January 2010, 08:12 PM   #8
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Default Hi!
Here is!
Regards zeoN_Rider
Old 28th January 2010, 08:53 AM   #9
Raymond
NO !!! L-07CII a bit less complex than Levinson ML-2
Yesterday failure was solved.
In fact only ( I don't know which one ) a bad solder on the mother board ( a double-side one ) and the solution was to re-solder on the two faces all components on the MC stage.
But without your help, Aparatusonitus and Tefbassuebertr, I think I lost my footing !
Raymond.
About my work on ML-2 amps :
Old 28th January 2010, 10:18 AM   #10
Good work Raymond...now enjoy your preamp!
KENWOOD L-07 CII  preampHide this!Advertise here!
Rmaf 07 Nelson Pass Pass Labs 181 26th April 2015 09:13 PM
kenwood L07C preamp,Any good? rtate Solid State 0 16th March 2009 06:18 PM
Kenwood C1 preamp schematic anyone ?? Jan Dupont Solid State 0 18th June 2007 03:29 PM
Kenwood KDC-MP625 No RCA Preamp Outputs.. Any ideas??? jefferzzzz Car Audio 2 24th December 2004 08:36 PM
Kenwood Model L-07 2002tii Solid State 3 10th February 2003 07:42 AM
Copyright ©1999-2017 diyAudio
