My RF controled PGA2320 MiniVol and ch selector
Old 21st January 2010, 09:36 AM   #1
quadtech is offline quadtech  India
Default My RF controled PGA2320 MiniVol and ch selector
I got a lovely MiniVol board with the PGA2320 chip driven by a AVR microcontroller from diyaudio member, theAnonymous1. The minivol provides vol up/down and mute, controlled by push switches or a rotary encoder.
The MiniVol is described here -
http://audio.gotroot.ca/minivol/
I also wanted a channel selector. So I rigged up a small
circuit around a CD4017 to step through the channels.
The DPDT relays are driven via 2N2222s.
To control everything, I got a cheap 4 Channel RF controlled switch on ebay. The receiver has a couple of
jumpers to choose the mode - toggle, latch or momentary.
I used the momentary mode. The 4 channels are used
for Vol Up, Vol Down, Mute and Channel select.
The open RF receiver/relay board, and the remote alongside are visible in one of the pics.
The PGA2320 is a really nice volume control chip, sweet
and transparent.
I wanted an appropriate box, so I put
the whole thing in a Ferrero Rocher chocolate box!
I am also attaching the Eagle files for the channel select circuit.
Old 8th February 2011, 06:11 PM   #2
linuxworks is offline linuxworks  United States
linuxworks's Avatar
a chocolate attenuator
I've used those ebay rf remotes before (I designed a camera shutter/focus remote based on those rf modules). they are pretty cool and easy to interface with.
for the relays - if you can get away with you - you can use ssr chips and have those trigger some other thing. the RF receiver modules are 5v based, I think, and so you add a small series R and go into an SSR chip, then use the 'contacts' pins to control the relays. it might make it a little quieter in operation and simplify things. you can also get the rf receivers without the relays onboard and have a smaller package.
My Photostream:http://www.flickr.com/photos/linux-works/
My RF controled PGA2320 MiniVol and ch selectorHide this!Advertise here!
PGA2310 vs. PGA2320 error401 Chip Amps 3 29th December 2011 08:51 AM
IC: MiniVol PGA23xx control board error401 Group Buys 6 20th March 2008 04:56 PM
Temp Variations CH to CH Zero Cool Everything Else 0 4th February 2007 01:25 PM
PGA2320: anyone? AudioWizard Parts 2 20th July 2005 03:39 PM
bridge a 4 ch amp into 3 ch? batonrye Car Audio 8 17th August 2004 10:37 PM
Copyright ©1999-2017 diyAudio
