Go Back   Home > Forums > Source & Line > Analog Line Level
Old 10th January 2010, 06:24 AM   #1
Default ESP Project 94A, What am I doing wrong? (Simple Mixer)
Need a little help on this one. I am trying to build this simple mixer/preamp only without the tone and balance controls. My test circuit is also omitting the volume pots (I'll be using a digital IC for that once it is working.)
As noted in the schem I'm using an OPA2211 for the opamp in single supply setup for testing. I get +2.2v at B1 but nothing comes out when the amp is connected.
Any ideas?
Old 10th January 2010, 08:47 PM   #2
ah, nevermind- figured it out. Even though the OPA2211 is supposed to be single supply it seems to need dual supply. Maybe only the OPA211 is single supply.
If anyone knows if I can omit the inverter buffer on the output that would be good to know. It looks like the volume pot I'm using might already have one:
QuickView - MAX5486 Stereo Volume Control with Pushbutton Interface
Great little preamp mixer but IMO ESP could use some work on joining schems better.
Simple preamp / mixer circuit - need help! HankMcSpank Solid State 3 4th July 2008 07:56 AM
simple 2->1 mixer amacks Parts 3 14th May 2007 08:31 PM
Simple mixer circuitry required lurkist Solid State 1 3rd September 2006 12:03 AM
you know when it all goes wrong? very simple question Si992 Solid State 9 28th May 2005 07:42 AM
simple line mixer JAZZ2250 Parts 8 18th January 2003 03:57 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
