oAudio BASH 500w high-pass/boost filter schematics/sim here oAudio BASH 500w high-pass/boost filter schematics/sim here - diyAudio
Old 6th January 2010, 12:25 AM   #1
s3tup is online now s3tup
s3tup's Avatar
Default oAudio BASH 500w high-pass/boost filter schematics/sim here
It's been a long time since i've reverse engineered something, yet i've never did full reversing, but just the part that took my interess.
But not today.
Today i took out the high-pass board out of oAudio 500w amp with intention to disable the boost option that is handy with sealed subs, yet makes lot of problems when you go vented (or passive radiator).
Yet, all the parts are messed-up - feedbacks, caps on opposite sides of the board, resistors placed on the basis of free space, and the last and greatest deception - The Knob Switch, which pins were shortened in opposite way:
If row1 pin1 and pin5 are shortened,
then row2 pin5 and pin4 are shortened too (weird...).
So here is the schematics, parts placement and simulation of the filter. It's Sallen-Key topology with output buffer, simple and clever.
The simulation and position of switches goes as follows:
12Hz 4,6 Red
16Hz 3,7 Yellow
20Hz 2,8 Green
25Hz 1,9 Blue
The resistor values were measured off-board, caps showed 0.99uF.
Tomorrow i'll try to play with values of resistors to get 3-6db rollof with variable frequency - for those who owns ported sub.
Old 8th February 2010, 11:01 PM   #2
spoonted is offline spoonted  Australia
How did you go removing the boost.
Old 2nd October 2012, 02:08 AM   #3
maxmercy is offline maxmercy  United States
Hello everyone,
Would anyone know the best way to mod the OAudio amp so that one of the settings was flat (no boost or subsonic filter)?
Thanks,
JSS
oAudio BASH 500w high-pass/boost filter schematics/sim hereHide this!Advertise here!
Boost in BASH plate amps.. JandG Multi-Way 2 16th March 2016 07:04 AM
F/S OAudio 300 watt Bash nvrgdenuf Swap Meet 5 7th July 2009 03:41 PM
FS: BASH plate amp 500W dsrviola Swap Meet 1 26th December 2007 09:53 PM
PE BASH 500W Plate Amp Viking552 Subwoofers 9 10th January 2007 06:56 AM
high gain 2nd order high pass active filter topology sreten Solid State 21 23rd March 2006 01:26 AM
Copyright ©1999-2017 diyAudio
