| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#21 |
Yes. DO listen very carefully to everything that GK says, suggests, and implies. He has great knowledge and _much_ useful information.
I forgot to mention that I have sometimes had too many problems when trying to use those white plug-in boards that you have used. It got to the point where it was more time-efficient to simply make printed circuit boards, even just for prototyping. And a PCB can give much better results, even if the protoboard is not having its own problems. You would need some way to be able to print your PCB layout on a laser printer. And you need some PCB blanks (mouser.com or search for FR4 on ebay.com). But with the method at Easy PCB (Printed Circuit Board) Fabrication, Using Laser Printer Toner Transfer, with a Household Clothes Iron and Glossy Inkjet Photo Paper; DIY at Home; Better AND Cheaper than Press-n-Peel ( PnP / P-n-P )! Making, Cheap , Economical , fastest fas , virtually everything else can be purchased almost anywhere that has civilization. I hate having to wait for something to come in the mail, such as etchant, when I want to fabricate a pcb. So I put together the method described, there. It works well-enough for one-offs and small production runs of one- or two-sided boards. You can go from screen image to finished board in less than an hour. There are lots of threads, on this site, that descuss the best way to route the traces, etc. I actually used MS Paint to do the artwork, at first. But a dedicated PCB-CAD package is a much better idea. There are threads here that discuss which ones are best, and free ones, etc. Tom |
#22 |
"One of the first things I learnt when beginning to play with opamps and pots.
Crappy MSpaint pic: " I confess to have made the same errors. Pause for Thought: an op-amp might have a loop gain of >100dB at 50Hz. Its quite easy to pick up 0.5uV over 6" of pcb trace between the feedback resistor junction and the input. Multiply this by 100dB . . . . say goodbye to high fidelity. Another few: Using non-unity gain stable op-amps in buffer or low gain circuits. Wonder why it sounds hard 'n harsh? Or 'veiled'? or noisy? Another classic. Plugging op amps into DIP sockets . . . .without thinking about the comp cap connections (some place the comp cap across pins 5 and 8 . . . and others across 1 and 8 . . ). Of course, this assumes the user understands why a comp cap is needed in the first place. Decoupling . . . plenty of opportunity to run into problems . . . Might be a good idea to make a page in the wiki 'Op-Amps for Everyman' |
#23 | |
#24 |
How is your project going? I am also going to try the burr brown route for a mic pre. You can also look at Jensen transformer site. They have a schematic showing JT-16 transformer in conjunction with SSM2017 which is precursor to INA217.
#25 | |
"Some lures are designed to catch fish, others are designed to catch fisherman." |
#26 |
Of course!
#27 |
Hi all,
I've resumed my INA217 project after almost one year! I'm going to modify some things on the circuit, that is to replace DC blocking caps with an input transformer particularly to add some color to the sound... I thought to use a transformer with 1:3.5 ratio from Cinemag (CMMI-3.5C) implemented in the way you see on the schematic I attached. With R5 and R6 of 15k the input impedance should be of 2k (differential input impedance seen by the microphone). Next step is to make a PCB following the guide written by gotee. I really need your critics and comments! ![]() M. |
#28 |
DRV 134 has floating balanced output. In case you take only one output signal, for example OUT+ vs. ground, you will get a lot of noise. You have to use true balanced output, i.e. OUT+ vs. OUT-, then the noise level would be approx. 20dB lower.
Pavel Macura http://www.linkedin.com/pub/pavel-macura/4/783/637 http://web.telecom.cz/macura/audiopage.html |
#29 |
Ettos,
I would add a 10 uF electrolytic from each chip power pin to ground. DC servos are "fun". Not sure these suggestions are needed or applicable (haven't simulated your circuit), but: - You could add diodes to temporarily greatly speed up the integrator's response when there is a very large DC offset. I'm not sure they would be desirable in this circuit, though. - You might want a good low-pass filter or two right after the differential integrator. - You might want a resistive voltage divider, just before the servo output signal goes into the inamp's REF input. - You will probably want a trimmer or pot, somewhere, to be able to adjust the circuit for zero DC offset at the inamp's output. Tom Last edited by gootee; 9th October 2011 at 05:15 AM. |
#30 | |
The best sounding way to manage variable resistances is ... to not use them: tune, measure their values and replace them with a metallic resistance of the same value. Last edited by Esperado; 16th October 2011 at 06:00 AM. |
| Cable for audio balanced line driver (drv134 ) | fluc | Solid State | 3 | 25th April 2008 05:30 PM |
| Audio Balanced Buffered Line Driver | Quattor | Solid State | 10 | 24th October 2005 04:52 PM |
| is DRV134 the best balanced line driver? | anli | Chip Amps | 4 | 13th December 2004 05:55 PM |
| Balanced Line Driver | Jerry Parker | Everything Else | 1 | 1st April 2003 05:32 PM |
| Aleph P 1.7 balanced line driver | Ignatz | Pass Labs | 0 | 31st October 2002 08:06 PM |
