impedance bridging problems - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 30th November 2009, 10:42 PM   #1
Wink impedance bridging problems
I built three "net" class a amps to drive headphones from line level sources. All were disappointing. I realised that common emitter input was always going to give problems in impedance bridging.
Heres my solution, emitter follower input.
I chose a high current capable device to drive the second stage. The amp sounds good to my old ears on all line level sources to my Grado's.
I don't have much test equipment, so i wondered if the 2n3055 collector load together with the emitter resistor was introducing an element of voltage gain (2?) what do you guys think?
Old 24th December 2009, 01:02 AM   #2
Of course there can't be any voltage gain from an emitter follower. Still it works nicely.
Impedance rate VS impedance stability TomatoBangBang Tubes / Valves 6 4th September 2008 10:46 PM
Impedance problems spsfahy Solid State 6 19th July 2008 05:42 AM
[Newbie] PA speaker impedance problems chaos.squirrel PA Systems 6 22nd December 2006 07:55 AM
Bridging, matching +, what impedance? edjosh23 Chip Amps 7 12th March 2005 09:42 PM
Need help understanding transformer impedance ratios and impedance matching percy Tubes / Valves 5 28th February 2005 08:35 PM
Copyright 1999-2017 diyAudio
