| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
So right now i'm using an Adcom preamp into a DBX active 2-Way crossover into amps (i forget the model numbers, but i can check later). All is well when using this to run the speakers and sub, but when I plug headphones into the headphone jack of the Adcom preamp, i get a LOT of noise, the noise does not seem to increase in volume as the music volume increases, so i can turn up the volume to drown it out, but that is obviously not desirable.
After messing around with it for a few minutes, i found that unplugging the preamp out cables fixes the problem. So somehow the connection from preamp to active crossover is causing lots of noise in the headphone output of the preamp? this seems very strange, since in my experience i have only had noise from an input, not an output (but my experience is not much). If anyone has any ideas of what i could do to fix it, they would be greatly appreciated |
#2 |
just another
I guess a question is in order
Tony. |
#3 |
The noise sounds like static with a high pitched hum/whine/tone. The noise is not constant, it sounds like some RF interference or something like that. It gets choppy for a few seconds, then holds constant, then the static gets louder, etc, it just keeps varying.
The Preamp is an Adcom GTP-450 and the Crossover is a DBX 223, if that helps at all |
#4 |
Oh, kind of a random question Tony, but, is Wintermute your last name? I'm curious because I have a friend (in southern California) with that last name who has relatives in Australia
-Scott |
#5 |
any ideas?
-Scott |
| help! annoying preamp noise | strangecargo | Everything Else | 4 | 9th September 2010 07:55 PM |
| Preamp -> Class-D = Noise | Cyberzim | Class D | 3 | 24th September 2009 05:35 PM |
| what causes noise in a SS preamp? | woodturner-fran | Solid State | 5 | 27th May 2007 11:33 AM |
| Re:preamp sputtering noise | Tualek53 | Tubes / Valves | 5 | 4th February 2006 07:07 PM |
| Preamp hiss noise | morfeas | Tubes / Valves | 10 | 17th June 2005 05:52 AM |
| Page generated in 0.07716 seconds (75.77% PHP - 24.23% MySQL) with 10 queries |
