| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#21 |
#22 | |
bc546 bc556 can stand 0.65w at 25C temperature. BC546 Q12 Q4 VCE=65V,amp is + -35v Q12 V(CE) + Q4 V(CE)=70V Q4 CE voltage is 35V,is not 70V. we can calculation through the simulation software. i use sanken 2SA1186 2SC2837 70M 100W in amp output stage. it performance nice. ![]() i will pay attention to you mention components. Last edited by ljm_ljm; 7th December 2009 at 01:16 AM. |
#23 | |
0.65W at a 25C CASE TEMPERATURE...i.e, on an infinite heatspreader... when Q12 conduct at 100%, Q4 is off and see a VCE of 70V less the gap and emitter resistor voltage drop of Q12, this make 68V AT LEAST.. power transistors are good, but for safe operation , replace as follow : Q4, Q9 : BD140 Q5. Q12 : BD139 all the best.. |
#24 | |
thanks . i have some the 2SB649 2SD669. do you know what the whole plastic parts for TO220 transistor darlington,preferably. |
#25 |
here the main simulation of the amp..
all simulated with output at +29 dbU,8 ohm load, wich is 50 w RMS ,close to clipping.. 1KHZ THD is 0.03 % 10 KHZ THD is 0.05 % 400HZ /7 KHZ 4/1 ratio IMD is at 0.03 % 2 to 200 KHZ bandwith, almost flat.. 1.5 uS rise and decay time, slew rate is 25V/uS also a 10KHZ sine wave on 8 OHM + 1 uF LOAD.... this seems encouraging, and i m going to build one again for verifications purposes, using the new transistors councelled by hugh dean.. next post when the thing is assembled.. regards, wahab |
#26 |
Banned
Looks like your using some nice wire, same silver wire as my self
J' |
#27 |
In the new version, I used the VAS = 2 N5551. It can work more VCE
#28 |
Hi there, firstly, thanks for a wonderful amp project, it sounds excellent.
It appears that the boards power supply max is 45V My transformer is 35Vac and 300VA. DC output after my 20000uF of cap should be around +-50VDC . Will this be too much for the board? i currently have it running on a 30VA 15-0-15 transformer and the amp sounds wonderful. Thanks and Regards John
Regards John |
| 50watt into 1ohm load with KAPPA 9 | tinitus | Solid State | 22 | 22nd November 2006 11:51 PM |
| tubes: Jcm 900 Slx 50watt | Stongelo | Tubes / Valves | 1 | 9th December 2005 09:32 AM |
| 50watt 8 inch driver question | psychosteve | Multi-Way | 0 | 24th September 2004 12:02 PM |
| 50watt Plexi Again | edsmith | Tubes / Valves | 2 | 23rd March 2004 07:14 PM |
| hey guys, i have a 50watt co2 laser in my garage. need anything etched? | travis | Everything Else | 13 | 14th July 2003 03:32 PM |
| Page generated in 0.09458 seconds (81.08% PHP - 18.92% MySQL) with 11 queries |
