Go Back   Home > Forums > Source & Line > Analog Line Level
Old 13th November 2009, 08:46 PM   #11
teleman is offline teleman  Norway
Looking at page 3,fig.2.4a http://www.jensen-transformers.an/an003/pdf in the unbalanced out put both the signal-common(0) & the (earth) ground wires are shorted.Is this correct or just an oversight?
Old 13th November 2009, 11:01 PM   #12
Speedskater's Avatar
Bill Whitlock of Jensen is one of few authorities on this type of circuit. So I think that is the correct planned connection. Both the input and output un-balanced jacks are connected to chassis ground. It's the same way in all the drawings.
Kevin
Old 14th November 2009, 12:29 AM   #13
Does this mean that both the unbalanced in/out common wires should be grounded to the chassis instead of the signal (0) ground? In that case won't any signal or a cable plugged in to these will see an open circuit,by virtue of the fact there won't be any direct connection between signal ground ie:0v & the chassis ground!
Then what would be the function of the signal ground?
Do you have any idea as to why it is wired this way? Would you mind elaborating this please 'cause I'm thoroughly confused now!
Old 14th November 2009, 09:05 AM   #14
the triangle symbol is the signal ground.
The fork symbol is the chassis.
What's the confusion?
Rane note165 might help.
regards Andrew T.
Old 14th November 2009, 11:05 AM   #15
The confusion is when both the triangles & forks are tied together as in fig.2.4 on page 9 in the http://www.jensen-transformers.com.an/an003.pdf !!
Old 14th November 2009, 11:28 PM   #16
It's not instead of the signal ground, it's in addition to the signal ground.
Kevin
Old 15th November 2009, 07:23 AM   #17
Ah,Yes of course & thank you for reminding me about the 2 wires + screen!......
Taking the cue from Kevin,I had another look at Douglas Self's pages,it suddenly dawned on me that I had completely forgotten about the 2 wires + the screen involved!
So sorry guys to have bothered you all unnecessarily!I do get wires crossed in my brain sometimes!Needs proper screening I suppose!!
Hacking a new output to mixer Tribat Parts 5 21st January 2009 08:00 AM
How to build a simple balanced mono line mixer jandalo Analog Line Level 4 8th November 2008 12:40 PM
buffer with balanced output udip Solid State 22 23rd February 2005 06:53 AM
ono balanced output pamaz Pass Labs 6 3rd March 2004 11:20 PM
balanced output wuffwaff Solid State 14 16th January 2002 06:54 AM
Page generated in 0.08971 seconds (72.95% PHP - 27.05% MySQL) with 11 queries
