| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 | |
If I wasn't planning on 'Summing' some inputs on the MX882 then I could have just used the MX882 to both up the levels on the way in to the DCX and then down the levels on the way out of the DCX. But by 'Summing' in the MX882, if I did try to use it both pre and post DCX then I would create a feedback loop. Hmmm, perhaps I should find a really cheap device that can do Summing..... Or just buy two MX882's, but that would seem a waste. |
#12 | |
Actually, perhaps I can just use the one MX882.
Each input can be set to split or mix mode. I thought the whole unit was either in split more or mix mode, but seems it can be done on an individual channel basis. So I could do... Main inputs, are the LPF (40Hz and below) output from my active main speakers. Input 1 could be the LFE channel which gets mixed into both the L & R main outputs. Set the main output levels appropriately for the DCX. This could then be feed into the DCX . The output from the DCX could then be feed back into the MX882 on channels 3 & 4. Set those channels to 'split' mode (so that they don't get summed to the main outputs and create a feedback loop). Set the output levels to what is appropriate for the inputs of the Quest 3004. Work out the appropriate gain or sensitivity on the Quest. I 'THINK' thats how it could work. Quote:
#13 |
I was wrong again... this is getting repetitive, me making mistakes that is
![]() I can't use the 'sum / mix' functionality if I want to do level matching on the outputs of the DCX as it would create a feedback loop. I 'think' I was right the first time.I 'think' I have to scrap the idea of combining the Low Passed (40Hz and below) from the L & R mains with the Home Theatre LFE channel. Summary: Input 1). could be a copy of the LFE (use a splitter cable from my Integra DHC-9.9), which I put in 'mix' mode, adjust gain for DCX input, and output straight out of Output 1. Input 2). could be a copy of the LFE (use a splitter cable from my Integra DHC-9.9), which I put in 'mix' mode, adjust gain for DCX input, and output straight out of Output 2. Input 3). this would be the L output from the DCX. Here we would lower the voltage to the whatever is needed by the Quest 3004 for the Left channel input. Input 4). this would be the R output from the DCX. Here we would lower the voltage to the whatever is needed by the Quest 3004 for the Right channel input. Damn, I hope I have it right this time.. talk about a merri-go-round in my head :P Last edited by Drizt; 10th November 2009 at 06:32 AM. |
| Hi All new here quest. about kappa pro | drumsz | Subwoofers | 0 | 7th November 2008 10:06 PM |
| Tweeter Quest | biovizier | Multi-Way | 8 | 17th July 2006 02:56 PM |
| The quest to fix my amp has begun! | wintermute | Solid State | 25 | 22nd December 2003 07:11 AM |
| The Quest | millwood | The Lounge | 14 | 26th July 2003 04:59 PM |
| Page generated in 0.08259 seconds (75.41% PHP - 24.59% MySQL) with 10 queries |
