| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
Hello,
I have a pair of mFonkens powered by a DIY Paradise Charlize II, I'm building a powered sub and would like to get your input on splitting the signal. I want to split the line level signal into two after my pre-amp, one side going directly to the subwoofer plate amp, letting it's cross over filter out the high frequencies. With the other line level signal, I would like to implement a filter, then put the signal into the Charlize. Can anyone suggest a simple passive line level 3rd or 4th order filter to take out everything below about 100Hz to reduce the load on the Charlize and mFonkens? Will this plan work, or is there a better way to achieve it? I would like to stay passive to avoid cost complexity, and line level to reduce the cable mess to a minimum. I have learnt a lot on these forums, and I really appreciate everyone's input. Cheers, David. PS. Here are two poor quality schematics of the plate amp, if it helps: One Two |
| Splitting A Line Level Signal. | Noumenon | Analog Line Level | 0 | 10th August 2007 01:57 PM |
| Splitting line level audio signals | squowse | Everything Else | 0 | 19th August 2006 04:21 PM |
| How do I turn an high current signal into a line level signal?? | sardonx | Tubes / Valves | 8 | 27th August 2005 12:16 PM |
| Line level signal delay circuit | wigginjs | Solid State | 3 | 26th September 2004 03:51 PM |
| how to bring down line level signal to preamplifier level | deji | Solid State | 15 | 15th April 2004 05:13 PM |
| Page generated in 0.05811 seconds (69.36% PHP - 30.64% MySQL) with 10 queries |
