| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 |
Just listening to the F1 in my system, I have had the unit for months but after initially using it and not being able to sort out the hum I had put it to one side.
But this morning (Happy New Year to all ) I decided it was time to try again - still the same old hum - so a search revealed this thread. I will start with the hum solution and then get the bits together for the psu upgrade.Is it possible to get a photo of the psu mod - just to be on the safe side? Alan |
#12 |
frugal-phile(tm)
Alan,
You might need to wait a few days. Duo is away visiting his Mom for the holidays. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#13 |
Just ground the pcb to chassie with a 10ohm resistor.
Not perfect but half the hum isnīt bad. Itīs also easy to disconnect VR1 from VR2, to get stereo subsignal, look at the schematic. But thatīs neadless. The only drewback, is that it has a negative signal amplification. Not god behavior for a passive preamp. I drive it with a LT-filter at output, and it sounds amazingly well. |
#14 | |
Thanks! Dave |
#15 |
Speakerholic
You can check here. He advertises new versions.
Creative Sound Solutions - Loudspeakers, Parts and DIY Speaker Kits |
#16 |
Thanks Cal, I appreciate it!
Dave |
#17 |
frugal-phile(tm)
Since Bob started adding a few upgrades to these -- regulated power supplies, optional stereo conversion -- they have been "flying off the shelves". I understand there are more on a boat from China.
Do note that the specified roll-off curves are not accurate (doesn't make it any less useful). Daniel & i are working on a set based on the unit i have here. dave
#18 |
Any comments about the sound quality?
#19 |
I use one of the F-1 units here (tried it before and after modifications). It sounds pretty good; it isn't obvious in the sound aside from the fact it's cutting up the spectrum for the speakers. The curves could be better, but I still find this quite useful when I'm running my transmission line sub.
| Reckhorn A-402 subwoofer amplifier - Warning!!! | sharpi31 | Solid State | 28 | 23rd November 2010 07:12 AM |
| Suggestions for a diy amp. | marbo | Solid State | 2 | 3rd October 2008 02:48 AM |
| Reckhorn A-400 Subwoofer Amp, lots of features! | sbrtoy | Swap Meet | 2 | 18th April 2008 11:22 PM |
| FS RECKHORN A-400 Subwoofer Amp | kffern | Swap Meet | 0 | 21st September 2007 12:19 AM |
| PSU suggestions for my DAC | ezkcdude | Power Supplies | 16 | 28th May 2006 07:00 PM |
| Page generated in 0.09688 seconds (77.93% PHP - 22.07% MySQL) with 10 queries |
