Go Back   Home > Forums > Source & Line > Analog Line Level
Old 11th October 2009, 11:24 PM   #1
Default Input Question
I want to configure an auxiliary input for an active preamp to accept headphone outputs from from CD players, mp3 players, etc.
Is it worth doing a voltage divider, or placing series resistors to properly load the headphone output of a source device, or do you just connect it directly to the preamp's input?
Old 12th October 2009, 04:37 PM   #2
Puffin is online now Puffin  United Kingdom
http://sound.westhost.com/project100.htm
Try that. It might be what you need.
Old 12th October 2009, 06:22 PM   #3
Originally Posted by Puffin View Post
Headphone Adaptor for Power Amplifiers
doh! Its for a projet 97 preamp from Rod's site (blush).
Actually, what I'm trying to do is create an input for a preamp that properly loads a headphone circuit.
Old 12th October 2009, 08:27 PM   #4
[QUOTE=
an input for a preamp that properly loads a headphone circuit.[/QUOTE]
What is that then?
Old 13th October 2009, 12:01 AM   #5
What is that then?
Its a voltage divider network for driving headphones safely with a power amp's speaker outputs. Handy, but kinda the opposite of what I need.
Old 1st December 2009, 09:06 PM   #6
Hi lhwidget
You are treading a path I painfully scouted. IMO line and headphone outputs definitely
need an active buffer input to following stages.Forget passive networks and don't bother with common emitter config. input. Use the most suitable ie emitter follower.(or FET gate follower)
You may consider bypassing your preamp with signals at this level unless its low gain.
cheers
PT P-1A I2S input question marcus1 Digital Source 2 19th December 2011 03:30 PM
Input pot question kacernator Tubes / Valves 9 1st April 2008 04:10 AM
another input cap question for SI t-amp schumpe Class D 27 10th July 2007 11:20 PM
pre amp question, need your input cidme Everything Else 4 2nd July 2007 08:40 PM
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 11:10 PM
Page generated in 0.08255 seconds (74.54% PHP - 25.46% MySQL) with 10 queries
