| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#11 |
i think i dont wanna make it.
i just ont like the sound. not my taste i think |
#12 |
http://glass-ware.stores.yahoo.net/aikampocboar.html
These are very easy kits to make and sound great
#13 |
A simple gain stage with some negative feedback would reduce the gain.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#14 |
How many 5687 tubes do you have?
#15 |
How about a 12ax7 gain stage with out the cathode decoupling capacitors ?
#16 | |
Theory (in simple terms) and an example with gain of 8.5 using the 7AX12 is here http://www.freewebs.com/valvewizard/localfeedback.html If you need a gain of 1 try a cathode follower. |
#17 |
Banned
bakpaosiomay,
12AX7 belongs to the big family of nonlinear tubes, 5687 is much better. |
#18 | |
The problem is that the rp is very high, so that the plate load MUST be high to run the tube linearly. There are a lot of circuits out there with 100-150k plate loads, and that's much of the source of the ECC83's bad reputation.
“There are no greater liars in the world than quacks, except for their patients.” - Benjamin Franklin |
#19 | |
Consider using your E88CC or 5687 as the preamplifier. Each has two triodes in the valve tube, so you only need one tube to do stereo. Looking at the E88CC datasheet suggest a reasonable operating point is... -2V bias 7.5 mA 80V anode voltage (Actually the 5687 will work at about those settings too). Some feedback from anode to grid (via a capacitor please) will reduce the gain. The output impedance is going to be a little high, so maybe you would need to follow it with a cathode follower stage. So maybe the E88CC as the amplifier part and the 5687 as the cathode follower? http://www.mif.pg.gda.pl/homepages/f...09/e/E88CC.pdf http://www.r-type.org/pdfs/5687.pdf http://www.tubezone.net/pdf/12ax7ecc83.pdf One final thing – if your amp has plenty of gain then maybe you do not need a preamplifier at all, in which case consider just using a potentiometer of about 5k to 10k between the source and the amplifier. |
#20 |
More on using your 5687…
As a cathode follower: http://www.glass-ware.com/tubecircui...llowers_2.html http://www.glass-ware.com/tubecircui...llowers_3.html As a preamplifier: If you have two pieces of 5687 then use one tube in each channel, and use the driver stage from this circuit diagram... http://stranwood.110mb.com/projects/carmen2.htm |
| Page generated in 0.10683 seconds (87.59% PHP - 12.41% MySQL) with 9 queries |
