| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
I have tried this schematic (a combination of components of various ZENs) as a preamp for Zen9 and got an unexpected good and powerful sound. The jFET is a russian vertical SIT transistor KP926A with the triode-like output characteristics. Quiescent current is 150 mA, what seems to be crazy for a preamp. Undistorted sinusuidal output voltage is up to 27V, that is good for a power follower.
#2 |
Enclose measurements for KP926A
#3 |
Wow, there are solid state devices with curves like that?
#4 |
Yep, SIT or V-FET: JFET with a gridlike gate buried inside the
channel... Acts like a vacuum triode, it has an intrisic space charge (or carrier gradient) feedback we know as "Mu". All the Japanese V-FETs dried up and dissapeared long ago, is this Russian version an available component, or rare??? Such feedback doesn't have to be intrinsic. O.H.Schade of RCA proved that long ago, transforming a set of Pentode curves into a Triode with feedback (not simply strapping the screen to the plate.) Nelson's Zen a modern example. But intrisic feedback from the space charge is awful quick way to stabilize voltage linearity, where you want minimum phase shift in your local feedback loop. It should be faster than any feedback path taken through external resistors. Mu of an input device inherits to the output in a Darlington or Sziklai arrangement. So you can abuse a small signal SIT, or Triode, and scale up the output current by the Beta of an ordinary BJT. Mu linearizes voltage gain for both, if anodes are wired directly together. But from the BJT's perspective, this is an external feedback path, not an intrisic one. |
#5 |
Banned
kenpeter,
I find that report a little bit vague... |
#6 |
Yep, my circuit does similar things. I just refer to it as a VAS...
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss |
#7 | |
I also tried to make the schematics more fast by employing casode - between the source of KP926A and the ground I inserted smaller jFET (not SIT) and made adjustments at 100 mA current. Due to decreased input capacitance of modified circuit it became very fast, it started to reproduce square wave up to 1 MHz, and I was close to heaven thinking I got something extraordinary. But during listening I have got ordinary sound, similar to what i have with my good preamp Parasound JC2. Cascode did not allow the triod-like features to operate. My current conclusion: the single-stage amps like some Zen versions benefit strongly from special preamplification stage; amplifier-speaker interaction is more important than good measurements with resistive load. |
#8 | |
#9 |
In the schematics from post #1 one can replace the current source by drain resistor. Without negative feedback, the voltage amplification factor was nearly 12 with 2K2 resistive load at the output.
#10 | |
| Page generated in 0.12965 seconds (72.50% PHP - 27.50% MySQL) with 10 queries |
