Yet another Volume controlers and source selections - Page 88 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 25th March 2013, 08:17 AM   #871
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Skype™ to tvicol
Yet another firmware update, ver 3.10, who address a very short display flickering who appear from time to time.
As usual available at vicol audio : r-2r volume controller
Tibi
Vicol Audio
Old 22nd April 2013, 07:21 AM   #872
tvicol's Avatar
12 channel volume-controller.
Tibi
Vicol Audio
Old 1st June 2013, 09:13 AM   #873
tvicol's Avatar
Another firmware update who implement gorgeous custom characters for attenuation display.
Scroll the page for latest version 3.11
Tibi
Vicol Audio
Old 3rd June 2013, 12:13 PM   #874
tvicol's Avatar
A short and dirty movie showing big digits operation.
Vicol-Audio R-2R volume controller short movie - YouTube
Tibi
Vicol Audio
Old 3rd June 2013, 12:51 PM   #875
FarmTech's Avatar
Send a message via MSN to FarmTech Send a message via Skype™ to FarmTech
hey,
looks nice Tibi
Only 1 error i found
the MUTE is located 1 place wrong in menu
if you look at video around 3.44 min
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 3rd June 2013, 12:56 PM   #876
tvicol's Avatar
Thanks FarmTech !
Mute was added in main menu due a custom version made for a client.
Normally this should be available only from remote, but ... I'm not decided to keep or remove him.
Thanks for observation.
Tibi
Vicol Audio
Old 3rd June 2013, 01:02 PM   #877
FarmTech's Avatar
Originally Posted by tvicol View Post
Thanks FarmTech !
Tibi
it was located 1 place wrong on LCD
it jump 1 place right on lcd , when it exit (menu) to main and show mute
if i did not explain it right
My Web Site
Old 3rd June 2013, 01:18 PM   #878
tvicol's Avatar
Ok, got it.
I'll move him 1 place right, so will no more "jump".
Thanks !
Tibi
Vicol Audio
Old 3rd June 2013, 02:10 PM   #879
rsavas is offline rsavas  Canada
Hello,
I have made big digits for a 4-line (4x40) character display, Newhaven NHD-0440WH-ATFH-JT or NHD-0440AZ-FL-YBW. I used the following code. I did not include the variable definitions but it is fairly obvious what they would be. It reqiures the xmega library that I have posted at MCS Electronics a few times. This code was posted in the public domain, so I gave credit to the original author. I also fixed a few bugs as well. It is the basics of the alarm clock function for my radio/media player. I use push button encoders for the UI. At night when in alarm set mode, I use big digits to display the current time. As you can see I use the Pca8565 as a RTC. It works great. Keeps time for days on a small super cap.
Enjoy and hope you can make use of it.
Rick Savas
'------------------------------Configure Port E---------------------------------
'Porte_dir = &B1011_1011 'If DIRn is written to one, pin is configured as an output pin.
'---------------------------------LCD Setup-------------------------------------
'use lcd4e2-xmega-vport0.lib and define port E as vport 0
Config Vport0 = E 'Real Port Direction
Ddre = &B1111_1111
Vport0_dir = &B1111_1111 'Virtual Port 0 = OUTPUT
Config Lcd = 40 * 2 'Config Lcd = 40 * 2(update 2.0.7.3 :Both are valid, but the * will become invalid in the future.
Dim ___lcde As Byte 'use for two Enable module type,0 = Top 2 rows, 1 = Bottom 2 rows
Initlcd 'same as asm "Rcall _init_lcd"
Waitms 100
___lcde = 0 'select the upper 2 line controller 'clear the LCD display
Cursor Off Noblink 'hide cursor
Cls
'reference p431 of Intro Into Practical Electronics Microcontrollers And Software Design, B. Collis 'select top controller
Deflcdchar 1 , 32 , 32 , 32 , 1 , 3 , 7 , 15 , 31 'these characters are used to build the bigdigits for alarm function
Deflcdchar 4 , 31 , 15 , 7 , 3 , 1 , 32 , 32 , 32
Deflcdchar 2 , 32 , 32 , 32 , 31 , 31 , 31 , 31 , 31
Deflcdchar 3 , 32 , 32 , 32 , 16 , 24 , 28 , 30 , 31
Deflcdchar 5 , 1 , 3 , 7 , 15 , 31 , 32 , 32 , 32
Deflcdchar 6 , 31 , 31 , 31 , 31 , 31 , 32 , 32 , 32
Deflcdchar 7 , 1 , 3 , 7 , 15 , 31 , 31 , 31 , 31
Deflcdchar 0 , 31 , 30 , 28 , 24 , 16 , 32 , 32 , 32
___lcde = 1 'select the upper 2 line controller 'clear the LCD display
Cls
'I_bigdigit = 0 'Debug,write big digits across display
'For Digitpos = 1 To 40 Step 4
'Show_bigdigit
'Incr I_bigdigit
'Waitms 100
'Next
'Wait 1
___lcde = 0
Locate 1 , 1
' 0123456789012345678901234567890123456789
'Lcd "****************************************" 'display this at the top line
Lcd "***DSP-Radio-Media Player FW v1.0.0.1***" 'startup banner
Locate 2 , 1
' Lcd "Encoder/switch/led,RTC,USB UART Testing "
___lcde = 1 'select the lower 2 line controller
Locate 1 , 1
Locate 2 , 1
'Deflcdchar 1 , 32 , 32 , 32 , 1 , 3 , 7 , 15 , 31
'Deflcdchar 4 , 31 , 15 , 7 , 3 , 1 , 32 , 32 , 32
'Deflcdchar 2 , 32 , 32 , 32 , 31 , 31 , 31 , 31 , 31
'Deflcdchar 3 , 32 , 32 , 32 , 16 , 24 , 28 , 30 , 31
'Deflcdchar 5 , 1 , 3 , 7 , 15 , 31 , 32 , 32 , 32
'Deflcdchar 6 , 31 , 31 , 31 , 31 , 31 , 32 , 32 , 32
'Deflcdchar 7 , 1 , 3 , 7 , 15 , 31 , 31 , 31 , 31
'Deflcdchar 0 , 31 , 30 , 28 , 24 , 16 , 32 , 32 , 32
'Test_bigdigit:
' Digitpos = 1
' For I_bigdigit = 0 To 9
' Gosub Show_bigdigit
' Waitms 100
' Next
' Wait 1
' Gosub Show_bigtime
' Wait 1
'Return
Show_bigtime:
'Call Pca8565_gettime()
Pca8565_minute_temp = Makedec(pca8565_minute)
Pca8565_hour_temp = Makedec(pca8565_hour)
'Pca8565_second_temp = Pca8565_second
___lcde = 0 : Locate 1 , 1
'Cls
'Lcd "1234567890123456789012345678901234567890"
Lcd " "
Locate 2 , 1
Lcd " "
___lcde = 1
Locate 1 , 1
Lcd " "
Locate 2 , 1
Lcd " "
If Pca8565_hour_temp > 12 Then Pca8565_hour_temp = Pca8565_hour_temp - 12
If Pca8565_hour_temp = 0 Then Pca8565_hour_temp = 12 'find the digit in the tens of hours position
I_bigdigit = Pca8565_hour_temp / 10 'e.g. 19/10 = 1 (byte arithmentic!!)
Digitpos = 1
If I_bigdigit > 0 Then
Show_bigdigit
Else
Disp_blank
End If
I_bigdigit = Pca8565_hour_temp Mod 10 'e,g. 19mod10 = 9 (finds remainder)
Digitpos = 5
Gosub Show_bigdigit
___lcde = 0
Locate 2 , 9
Lcd Chr(6)
___lcde = 1
Locate 1 , 9 'Locate 3 , 9
Lcd Chr(2) 'find the digit in the tens of minutes position
I_bigdigit = Pca8565_minute_temp / 10 'e.g. 21/10 = 2 (byte arithmentic!!)
Digitpos = 11
Gosub Show_bigdigit 'find the digit in the units of minutes position
I_bigdigit = Pca8565_minute_temp Mod 10 'e.g 21mod10 = 1 (finds remainder)
Digitpos = 15
Gosub Show_bigdigit 'display the seconds in the bottom corner of the display
'Locate 2 , 19 'Locate 4 , 19
Digitpos = 19
If Am_pm = 0 Then
I_bigdigit = 11
Else
I_bigdigit = 12
End If
Gosub Show_bigdigit
'If Pca8565_second_temp < 10 Then Lcd "0"
'Lcd Pca8565_second_temp
Return
Show_bigdigit:
Select Case I_bigdigit
Case 0 : Disp0
Case 1 : Disp1
Case 2 : Disp2
Case 3 : Disp3
Case 4 : Disp4
Case 5 : Disp5
Case 6 : Disp6
Case 7 : Disp7
Case 8 : Disp8
Case 9 : Disp9
Case 10 : Disp_dot
Case 11 : Disp_a
Case 12 : Disp_p
Case 12 : Disp_m
End Select
Return
Disp0:
___lcde = 0
Locate 1 , Digitpos 'line 1
Lcd Chr(1)
Lcd Chr(2)
Lcd Chr(3)
Locate 2 , Digitpos 'line 2
Lcd Chr(255)
Lcd " "
Lcd Chr(255)
___lcde = 1 'line 3
Locate 1 , Digitpos 'Locate 3 , Digitpos
Lcd Chr(255)
Lcd " "
Lcd Chr(255)
Locate 2 , Digitpos 'Locate 4 , Digitpos
Lcd Chr(4) 'line 4
Lcd Chr(6)
Lcd Chr(0)
Return
Disp1:
___lcde = 0
Lcd " "
Lcd Chr(1)
Lcd " "
Lcd Chr(5)
Lcd Chr(255)
Lcd " "
___lcde = 1
Lcd " " 'line 3
Lcd Chr(255)
Lcd " "
Lcd Chr(6) 'line 4
Lcd Chr(6)
Lcd Chr(6)
Return
Disp2:
___lcde = 0
Lcd Chr(1)
Lcd Chr(2)
Lcd Chr(3)
Lcd Chr(6)
Lcd " "
Lcd Chr(255)
___lcde = 1 'line 3
Lcd Chr(7)
Lcd Chr(6)
Lcd Chr(0)
Lcd Chr(6) 'line 4
Lcd Chr(6)
Lcd Chr(6)
Return
Disp3:
___lcde = 0
Lcd Chr(1)
Lcd Chr(2)
Lcd Chr(3)
Lcd " "
Lcd Chr(2)
Lcd Chr(255)
___lcde = 1 'line 3
Lcd " "
Lcd " "
Lcd Chr(255)
Lcd Chr(4) 'line 4
Lcd Chr(6)
Lcd Chr(0)
Return
Disp4:
___lcde = 0
Lcd Chr(2)
Lcd " "
Lcd " "
Locate 2 , Digitpos 'Line 2
Lcd Chr(255)
Lcd " "
Lcd Chr(255)
___lcde = 1 'line 3
Lcd Chr(255)
Lcd Chr(255)
Lcd Chr(255)
Lcd " "
Lcd " " 'line 4
Lcd Chr(6)
Return
Disp5:
___lcde = 0
Lcd Chr(2)
Lcd Chr(2)
Lcd Chr(2)
Lcd Chr(255)
Lcd Chr(2)
Lcd Chr(2)
___lcde = 1
Locate 1 , Digitpos 'Locate 3 , Digitpos 'line 3
Lcd Chr(2)
Lcd " "
Lcd Chr(255)
Lcd Chr(4) 'line 4
Lcd Chr(6)
Lcd Chr(0)
Return
Disp6:
___lcde = 0 'line 1
Locate 1 , Digitpos
Lcd Chr(1)
Lcd Chr(2)
Lcd Chr(3) 'Line 2
Locate 2 , Digitpos
Lcd Chr(255)
Lcd Chr(2)
Lcd Chr(3)
___lcde = 1 'line 3
Lcd Chr(255)
Lcd " "
Lcd Chr(255) 'line 4
Lcd Chr(4)
Lcd Chr(6)
Lcd Chr(0)
Return
Disp7:
___lcde = 0
Lcd Chr(1)
Lcd Chr(2)
Lcd Chr(3)
Lcd " "
Lcd " "
Lcd Chr(255)
___lcde = 1 'line 3
Lcd " "
Lcd " "
Lcd Chr(255)
Lcd " "
Lcd " " 'line 4
Lcd Chr(4)
Return
Disp8:
___lcde = 0
Lcd Chr(1)
Lcd Chr(2)
Lcd Chr(3)
Lcd Chr(255)
Lcd Chr(2)
Lcd Chr(255)
___lcde = 1 'line 3
Lcd Chr(255)
Lcd " "
Lcd Chr(4)
Lcd Chr(6)
Lcd Chr(0)
Return
Disp9:
___lcde = 0
Lcd Chr(1)
Lcd Chr(2)
Lcd Chr(3) 'line 2
Locate 2 , Digitpos
Lcd Chr(255)
Lcd " "
Lcd Chr(255)
___lcde = 1 'line 3
Lcd Chr(4)
Lcd Chr(6)
Lcd Chr(4)
Lcd Chr(6)
Lcd Chr(0)
Return
Disp_dot:
___lcde = 0
Lcd " "
Lcd " "
Lcd " " 'line 2
Locate 2 , Digitpos
Lcd " "
Lcd Chr(255)
Lcd " "
___lcde = 1 'line 3
Lcd " "
Lcd Chr(255)
Lcd " " 'line 4
Lcd " "
Lcd " "
Lcd " "
Return
Disp_a:
___lcde = 0
Lcd Chr(1)
Lcd Chr(2)
Lcd Chr(3) 'line 2
Locate 2 , Digitpos
Lcd Chr(255)
Lcd Chr(2)
Lcd Chr(255)
___lcde = 1 'line 3
Lcd Chr(255)
Lcd " "
Lcd Chr(6)
Lcd " "
Lcd Chr(6)
Return
Disp_p:
___lcde = 0
Lcd Chr(1)
Lcd Chr(2)
Lcd Chr(3) 'line 2
Locate 2 , Digitpos
Lcd Chr(255)
Lcd Chr(2)
Lcd Chr(7)
___lcde = 1 'line 3
Lcd Chr(255)
Lcd " "
Lcd " " 'line 4
Lcd Chr(6)
Lcd " "
Lcd " "
Return
Disp_m:
___lcde = 0
Lcd Chr(1)
Lcd Chr(2)
Lcd Chr(1) 'line 2
Locate 2 , Digitpos
Lcd Chr(255)
Lcd Chr(6)
Lcd Chr(255)
___lcde = 1 'line 3
Lcd Chr(255)
Lcd " "
Lcd Chr(255)
Lcd " "
Lcd Chr(255)
Return
Disp_blank:
___lcde = 0
Lcd " "
Lcd " "
Lcd " " 'line 2
Locate 2 , Digitpos
Lcd " "
Lcd " "
Lcd " "
___lcde = 1 'line 3
Lcd " "
Lcd " "
Lcd " " 'line 4
Lcd " "
Lcd " "
Lcd " "
Return
Old 3rd June 2013, 02:51 PM   #880
Default A picture for you
What do you think?
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2017 diyAudio
