Yet another Volume controlers and source selections - Page 87 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 3rd March 2013, 07:10 PM   #861
FarmTech's Avatar
Send a message via MSN to FarmTech Send a message via Skype™ to FarmTech
Originally Posted by RS232 View Post
Thanks FarmTech
I was hoping do see the modified .bas file but this is OK.
Going to give up for now, can get the programer (USBASP) to connect to the atmega.
Tried Ponyprog, avrstudio, winavr, extreme burner and a free version from bascom avr and nothing.
Going to look for a serial programer.
Ric
its in the ZIP
what USBASP programmer did you get link
I used mine USBASP and it was OK
I used Bascom & khazama both works
Mine have 2 jumpers 1 for programmer update and other to select 5V or 3.3V
did you install libusb driver ?? see http://www.fischl.de/usbasp/
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 3rd March 2013, 10:55 PM   #862
RS232 is offline RS232  United Kingdom
its in the ZIP
did you install libusb driver ?? see fischl.de - USBasp - USB programmer for Atmel AVR controllers
The .bas file in the .zip is the original one all the line for the PGA2310 are still there (or I'm missing something)
My USBASP is the black one, I know that there is at least 1 jumper for the 5V/3.3V selection but not sure about the second one.
About the software I'm starting to think that the problem is my laptop ( Vaio VGN-NR71B with Win 7 )
What is doing my head in is that I programed hundreds of avrs before (8515, atmega128...) and 32bits processors (Jtag) for digital set top boxes and never had so much trouble.
Going to try in another computer ( going to put one together) with win98 and XP and try again this week
Ric
Old 3rd March 2013, 11:10 PM   #863
FarmTech's Avatar
The .bas file in the .zip is the original one all the line for the 2311 are still there (or I'm missing something)
ric
Yes the code you don't need have color GREEN that REM code not in use
but here is a clean up bas
you still just write a color of you'r USBASP
to see what version yo have I do need the link to the USBASP you got
there are some of them that use reg as USB HID not USBASP so you need other program for this models
on ebay its the one with cover in many colors
software AVR_fighter
or serach for progisp that works ok
or check out uwezi blog about how to make it a "real" USBASP
My Web Site
Old 4th March 2013, 05:49 PM   #864
This is the one I bought.
Bought from UK seller but looks like they all come from the same place.
And tanks for the link
Old 4th March 2013, 06:02 PM   #865
FarmTech's Avatar
Ric ,
Check this links :
ER9X Hacks - Page 6 - R/C Electronic Projects - RC-CAM Forum
9x forums • View topic - WARNING: Known problematic USBASP
My Web Site
Old 5th March 2013, 06:02 AM   #866
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Skype™ to tvicol
New Vicol-Audio firmware version 3.8 is available for download on vicol audio : r-2r volume controller
This will correct some problems with editing main menu.
Tibi
Vicol Audio
Old 8th March 2013, 04:09 AM   #867
Junie is offline Junie  Philippines
Hi Tibi,
I think I mess up the input selection editing, kindly let me know how to reset to default settings?
Junie
Old 8th March 2013, 06:35 AM   #868
tvicol's Avatar
Hi Junie,
There is no default.
Once you have started to edit and you have saved, to get to default you need to edit back.
To edit and change menu´s you need to setup a remote first. Than use the chan+/- to change characters and vol+/- to move to next character. Add one more dummy character and press, on the remote, mute to validate and power to save new menu name.
To edit CD and change to SOURCE you need to press Input push button till Edit Input Text, than rotate encoder.
CD will appear.
From this point on use remote to edit.
Add one more character at the end of SOURCE.
EX: SOURCEA
Press Mute to validate
Press power to save.
That´s all.
Please also have a read on this documentation (page 3):
https://docs.google.com/viewer?url=h...&embedded=true
Also please note that there are two open collector transistors Q8 and Q9.
Q9 can be used to command a external relay for power on/off and Q8 have a delay for powering a tube plate relay, in case you use VC for a tube equipment.
Tibi
Vicol Audio
Old 8th March 2013, 08:24 AM   #869
FarmTech's Avatar
CD will appear.
EX: SOURCEA
That´s all.
Hi Tibi ,
you can make it show "Space" and not A if you make a change in Sub Edit_input_txt:
Case Mut_a :
here you have .
Code:
             Lcd X                                     'show the new text for input
                  My_chr = 65
                  X_chr = 1
                  My_string = ""
                  Locate 2 , X_chr
                  Lcd Chr(my_chr)
                  Shiftcursor Left
change My_chr = 65 to My_chr = 32
only diffrent is you have to scrool past 0-9 before you have letters
but it dont show the extra A when saving
But , you can edit in Case Shift_l : & Case Shift_r : to jump to letters order Letters, numbers
try this for Case Shift_l :
Code:
   Case Shift_l : Incr My_chr
              If My_chr = 33 Then My_chr = 65               'from space to A
              If My_chr > 90 Then My_chr = 48               'from Z to 0
              If My_chr = 58 Then My_chr = 32               'from 9 to  space
if that will make it more easy for user
now it go space to A-Z then 0-9 and back to space
well just a Idea ...
My Web Site
Old 8th March 2013, 08:30 AM   #870
tvicol's Avatar
Thank you for this suggestion, FarmTech !
Tibi
Vicol Audio
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2017 diyAudio
