| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#811 | |
vicol audio kit works OK no problems I was wrong by me to add info for china board here in this topic it have nothing to do with the vicol audio kit !!! I know that some of the users here have this china board thats why I put link here to I only made some "custom change" to vicol audio kit software as as extra funktion thats all so no problem to get a vicol audio kit Last edited by FarmTech; 14th February 2013 at 12:57 AM. |
#812 |
I have PM Mod to remove the 2 post (#808 #809 )
about China board in this Thread so no one gets confused about it again
#813 | |
And I am a bit upset by this allegations. Even in the first version firmware was working perfectly but lacking in some features . Now we are at 3.5 version of firmware , and on the 1.3 ...1.5 version Farmtech come with some ideas / improvement / features at that time ( 3..2 years ago ) and we exchange some message about some feature that Farmtech suggest and then implemented by him by adding a lot of code for a version which at that time added vu-meter RC5 programmable IR command and text changing name of input channel . At that time it was for me some oppening eyes as I was not aware that some user want this. Later that year i was again rewriting all the code . Now in the last firmware ( v3.5 ) there is very little from the collaboration between me and Farmtech (only the subroutine RC5 programming remain (which replace the Bascom native RC5 function ) !!!! THX FARMTECH again for that !!!! ) as everything in firmware is written by me again and again by the years. As now Farmtech is a dear friend of mine , i thank him for all the job is doing on this thread for tailoring and writing software in Bascom for all users that need it . (Now I do not have the time that I was sharing for users in those years ) Hope everything is clear now ? Ok ? As you see there is no other link / involvement from Farmtech to / with vicol-audio, nor hiding something about this.
There are not better tube than 6P3S and 6N2P for my ears ! Last edited by danzup; 14th February 2013 at 07:11 AM. |
#814 |
As allways last firmware for vicol audio R2R controller can be downloaded from :
vicol audio : r-2r volume controller There you will see the first comercial version ( from autumn 2008 ) v1.0 and last comercial version now 3.5 (today 14.02.2013). Last version print volume as attenuation in dB from -63 dB to 0 dB.
There are not better tube than 6P3S and 6N2P for my ears ! |
#815 |
#816 | |
Congratulation .
#817 |
#818 |
Hi Kim, wanted to add SI4703 to the TDA7439 code you wrote for me, is it possible since my system is running on 3.3 volts i think we could do it hardware wise. no problems yet
need you to match the two codes. in to one.
#819 |
and yes. tda7439 is on 5 volts but i do have P82B96 so i dont think we should have problem with level shifting i2c. and i remember you ahd also ordered those ic's last year right. along with the SI4703 board from sparkfun.
#820 | |
Yes it run 3.3V via levelshift http://www.sparkfun.com/datasheets/B...x-Eval-v11.pdf |
| source selector / volume hum in Aikido | cbutterworth | Tubes / Valves | 1 | 28th March 2007 07:34 AM |
| Source for volume knobs? | Alois | Pass Labs | 4 | 3rd July 2005 05:12 PM |
| IC Controlers for Class D Power stage | frozenpod1 | Class D | 14 | 17th May 2005 03:25 PM |
| Swichable source and volume pot. Whats the best way? | sounder | Chip Amps | 2 | 22nd September 2003 06:29 PM |
| detented volume pots... source? | Mach_Y | Parts | 2 | 1st June 2003 05:23 PM |
