| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#71 |
Okay, maybe that was five hours...
Thanks guys for such positive feedback, catch some more then... ![]() This is the MCU board for PLCC atmega. This one took me some more, needed to spend half a day digging the datasheets. Now only the PSU PCB will remain. Come back with updates soon. |
#72 |
Danzup,
as far as I understand, you've used BASCOM-AVR for creating and compiling the code. What did you use for flashing the chip itself, I mean - which schematic and software? I am planning to build the simplest-ever-possible type of ISP programmer - appreciate your suggestions. |
#73 |
Vikt0r,
as for me I soldered very simple "USBasp - USB programmer for Atmel AVR controllers". Original link: fischl.de - USBasp - USB programmer for Atmel AVR controllers BASCOM-AVR supports USBasp since version 1.11.9.6
#74 |
Thanks, Pryanick, but...
No problems to solder it together, but it still requires programming the Atmega8. Since I don't have anything yet - I need a simpler programmer at first. Maybe that would make sense to solder a USB one later. |
#75 |
http://www.diyaudio.com/forums/group...ction-pcb.html |
#76 |
Or use this one. Today I programmed my Mega16 without problems.
#77 | |
It is STK200/300 programmer header for parallel port . In Bascom this must be set in the programmer adapter type . Bascom AVR compiler you will find to download for free . On the schematics I forgot to draw the signals for programming so you must use the following pins of Atmel : Reset , Miso , Mosi , SCk , 5Vcc , Gnd . Do not forgot to program only the fusebit : Internal RC 8Mhz oscillator.
There are not better tube than 6P3S and 6N2P for my ears ! |
#78 |
Wow,
thanks guys! One of these will definitely do for me, found an ALS244 already. Interesting founding that some different (and incompatible!) pinouts for the ISP exist. The Atmel appnote recommends a 6 pin header, while at many designs a 10-pin one can be found.Which one is more standard? Another question - would this all SW accessing the LPT port work under Win7? Has anyone tested it? Oh... the WIP, if anyone's interested Very draft yet, just finished soldering, didn't even wash the board.
#79 |
Today I connected boards and turned power on. Well, I have some problems.
First of all, I reversed A and K on LCD backlight, so it must be corrected (my post #55 in this thread). Then, pushbutton for on/off can't turn off until backlight is on. Third, and most important, is that only three of six relays for volume work. I checked resistor, transistor and relay chains, all six of them are working properly, I just don't get enough voltage from pins to open transistor. I programmed chip with internal 8MHz clock, but I have delay between steps for volume aprox. 1 second, and for input select aprox. 2 seconds. Is it OK? Tommorow I'll reprogramm chip and, if it still doesn't work properly, I have to try with another mega16. I used all precautions against static electricity, I just don't belive that I damaged it. |
#80 | |||
What transistors did you use? Are you sure they're darlingtons? What voltage do you use to power Atmega? Quote:
One more thing: did you try the IR remote control? Does it work for you? |
| source selector / volume hum in Aikido | cbutterworth | Tubes / Valves | 1 | 28th March 2007 07:34 AM |
| Source for volume knobs? | Alois | Pass Labs | 4 | 3rd July 2005 05:12 PM |
| IC Controlers for Class D Power stage | frozenpod1 | Class D | 14 | 17th May 2005 03:25 PM |
| Swichable source and volume pot. Whats the best way? | sounder | Chip Amps | 2 | 22nd September 2003 06:29 PM |
| detented volume pots... source? | Mach_Y | Parts | 2 | 1st June 2003 05:23 PM |
