Yet another Volume controlers and source selections - Page 77 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 18th November 2012, 10:09 AM   #761
FarmTech's Avatar
Send a message via MSN to FarmTech Send a message via Skype™ to FarmTech
Hi Adrian ,
If the Remote have to low volt on battery then it can be a problem
you did not addon any files in post so what version do you use
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 18th November 2012, 10:58 AM   #762
FarmTech's Avatar
Default code for Rda5807 FM Stereo Digital Radio Module
If you need a simple radio modul I tested this
Rda5807 FM Stereo Digital Radio Module it can be found on Ebay
link to datasheet & ebay in the file
Addon Test code
it use 2 buttons to setup freq +-0.1 Mhz steps as simple test
My Web Site
Old 18th November 2012, 11:45 AM   #763
atupi is offline atupi  Romania
Sorry about forgetting attachment.
I have tested several rc-5 remotes and same behaviour.
For example for increasing/decreasing volume i need to press twice very fast the designated key to have effect on the controller.
Same for changing input i need to press twice very fast the channel up to change the input. I feel is something related to the freq of the impulses from remote.
All the credits to the attached software to Danzup
I think will be a great combination of Farmtech software with learn feature and my setup wich is described in the attached software.
Old 18th November 2012, 02:05 PM   #764
FarmTech's Avatar
Hi Adrian,
I like you to try the RC5 tester
I change the lcd and MCU for your setup
now you can run this on your board to test the RC5
see if you have same problems here
see ADDON file
what version of bascom do you use ?
there have been problems with RC5 in some versions
current version is 2.0.7.6 or 2.0.7.5.002
in the ZIP the HEX and BIN is compile with latest version
My Web Site
Last edited by FarmTech; 18th November 2012 at 02:11 PM. Reason: added info about bascom-avr version
Old 18th November 2012, 08:30 PM   #765
I will try to write de software tomorrow. What results i should expect ?
Right now i'm using a universal remote and i choose my own codes but for near future i ordered and plan to use this one Chunghop Universal Learning Remote Control L102 Silver | eBay
Old 18th November 2012, 09:51 PM   #766
FarmTech's Avatar
Hi Adrian,
This is a image of the lcd from remote tester
it show Address / Command & some text
more info in page 28 post #271
My Web Site
Old 26th November 2012, 08:35 PM   #767
Hi Farmtech and sorry for delayed reply, some stuff more important than DIY unfortunately.
I have programmed my Atmega 8515 with your test software but nothing on display, no sign of anything. I attach again the my working software maybe something is wrong.
Because you asked me i use Bascom 2.0.7.5.003 version Demo.
Old 26th November 2012, 10:25 PM   #768
FarmTech's Avatar
Hi Adrian,
Can't use hex file
but I can look at the bas if you PM it to me
And the setup of compiler
$hwstack = ??
$swstack = ??
$framesize = ??
you maybe have it setup in bascom under
menu Options/compiler/chip (M8515)
maybe the SWstack is to low set
Bascom-avr latest is 2.0.7.6
the RC5 tester used the setup for RC5 and lcd
from "adrian encoder 4 intrari.bas"
Code:
Config Lcdpin = Pin , Db4 = Portc.2 , Db5 = Portc.3 , Db6 = Portc.4 , Db7 = Portc.5 , E = Portc.1 , Rs = Portc.0
Config Lcd = 16 * 2
Cursor Off
Cls
Config Rc5 = Pind.3
My Web Site
Old 26th November 2012, 10:59 PM   #769
FarmTech's Avatar
Hi Adrian,
try change RC5 setup to :
Config Rc5 = Pind.3 , Wait = 2000
the Wait , is now setup as older versions of Bascom
see help Config RC5
My Web Site
Old 10th December 2012, 06:09 PM   #770
Hi again Farmtech!
I have tested again and bad luck.
I'm using Bascom 2.0.5.0 wich is capable to compile sources bigger than 4096k and tried to add that command Wait = 2000 after Config Rc5 = Pind.3 but very strange the Uc is not doing anything , is dead.
Also the same result with the previous software RC5 Test.
What else can be done, sorry i'm not more useful
PS. Attached again the running sw
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2017 diyAudio
