Yet another Volume controlers and source selections - Page 73 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 24th February 2012, 11:40 PM   #721
Jempie is offline Jempie  Indonesia
Still don't get it right
the gain of my preamp is to high so when the volume is 0 there is still a lot of sound
i have the regular board of vicol with 6 relais
want to make the steps bigger to reduce the volume
I have try the calculator of JvE Logarithmic Attenuator Calculator
1.5 dB steps
10k 10k 6.8k 4.7k 3.3k 1.5k
39R 680R 3.3k 10k 27k 56k 10k
2.0 dB steps
10k 10k 8.2k 5.6k 3.9k 2.2k
6.8R 270R 1.8k 6.8k 18k 39k 10k
what do i wrong
Old 25th February 2012, 11:44 AM   #722
Which one is the correct value for R31 ? In first release (ver 1.0) R31 for R2R 82K and shunt 16K. Now in rev 1.1 R31 for R2R 10K and shunt 82K.
Didiet
Old 25th February 2012, 01:50 PM   #723
Is there and calculation sheet to calculate the resistor value
Old 25th February 2012, 05:51 PM   #724
tvicol is offline tvicol  Romania
tvicol's Avatar
Send a message via Skype™ to tvicol
Didiet
Didiet,
The correct value for R31 R-2R operation is 82K.
There is a mistake in rev 1.1 drawing which I'll correct.
Tibi
Vicol Audio
Old 25th February 2012, 05:53 PM   #725
tvicol's Avatar
Jempie,
Use Jos calculator Logarithmic Attenuator Calculator
Tibi
Vicol Audio
Old 25th February 2012, 06:31 PM   #726
tvicol
if I use the Jos calculator, your board is 10K use 6 relais 1 db attenuation
then the resistor value are;
10k 8.2k 5.6k 3.9k 2.2k 1k
270R 1.8k 6.8k 18k 39k 82k 10k
if i compare it to your value it's totally different
could you please explane
which steps must i do to get it work right on your board
thanks
Old 25th February 2012, 07:10 PM   #727
tvicol's Avatar
tvicol
thanks
The values are pretty the same, depends only the reference in/out which is reversed.
For 1dB step attenuation and 63dB total attenuation, you must have:
R30 - 1K
R31 - 82K
R32 - 2K5
R33 - 47K
R34 - 5K8
R35 - 27K
R36 - 15K
R37 - 16K
R38 - 53K
R39 - 11K
R40 - 390K
R41 - 10K
For 1,5dB step attenuation and 95dB total attenuation, you must have:
R30 - 1K8
R31 - 68K
R32 - 3K9
R33 - 33K
R34 - 10K
R35 - 22K
R36 - 33K
R37 - 15K
R38 - 150K
R39 - 10K
R40 - 2M7
R41 - 10K
However I suggest you to go for something in between and choose 1,2dB step attenuation for a total of 76dB, which I believe will be more than OK.
R30 - 1K5
R31 - 82K
R32 - 3K3
R33 - 39K
R34 - 6K8
R35 - 22K
R36 - 22K
R37 - 15K
R38 - 82K
R39 - 12K
R40 - 820K
R41 - 10K
Tibi
Vicol Audio
Old 27th February 2012, 01:23 AM   #728
Originally Posted by tvicol View Post
Didiet,
Tibi
Thanks for clarification. Howto calculate value R-Shunt, so i can expand to 64 step for R-Shunt?
Didiet
Old 5th March 2012, 08:33 AM   #729
longpcb is offline longpcb  Viet Nam
Send a message via Yahoo to longpcb
Delete!
Old 5th March 2012, 11:04 AM   #730
tvicol's Avatar
Didiet
Sorry for late replay, but I do not get mail notifications from this thread ... :-(
Our volume-controller can operate in shunt up to 32 steps.
A shunt calculator you may find on this page:
50-Step Shunt Attenuator Resistor Calculator - Neville Roberts
Tibi
Vicol Audio
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright 1999-2017 diyAudio
