Yet another Volume controlers and source selections - Page 71 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 10th January 2012, 09:45 AM   #701
FarmTech's Avatar
Send a message via MSN to FarmTech Send a message via Skype™ to FarmTech
Originally Posted by didiet78 View Post
Danzup, in post Yet another Volume controlers and source selections can i just change PGA2310 with PGA2311 and change analog supply with +/-5V without change the HEX file?
Didiet
PGA2310 & PGA2311 use same software just the VOLT(+-12 & +-5) is diffrent
Old 10th January 2012, 02:22 PM   #702
Thanks Farmtech
Old 11th January 2012, 12:55 PM   #703
FarmTech's Avatar
Default TDA7439 ATMEGA8
Hi
Finish the test program for TDA7439
'ATMEGA8
'fusebit INT 8 Mhz
' LINK TO DATASHEET http://www.atmel.com/dyn/resources/p...ts/doc2486.pdf
' ENCODER/BUTON
' Portd.0 MENU Button
' portD.1 Encoder B
' portD.2 Encoder A
' GND Encoder C
' LINK to DATASHEET http://www.sparkfun.com/datasheets/C.../TW-700198.pdf
' TDA7439
' SDA Pin 1 To Portc.4
' SCL Pin 30 To Portc.5
' 2 * 4K7 RES to pullup SDA & SCL to +5V
' LINK TO DATASHEET http://www.datasheetcatalog.org/data...onics/4291.pdf
' LCD 16x2
' Rs = Portb.0
' E = Portb.1
' Db4 = Portb.2
' Db5 = Portb.3
' Db6 = Portb.4
' Db7 = Portb.5
' RW = GND
' Add a potmeter for contrast !!!
' FUNCTIONS
' INPUT 1 to 4
' VOLUME 0 to -56 db
' INPUT GAIN 0 to 15 db
' BASS -14 to +14 db
' MIDDLE -14 to +14 db
' TRIBLE -14 to +14 db
' MENU AUTO RESET TO MAIN menu (volume) after 3 sec
Video Here :
VIODE OF LCD MENU
Files Here :
HEX BIN for ATMEGA8 & schematic
Old 12th January 2012, 05:30 AM   #704
FarmTech's Avatar
Exclamation TDA7439 ATMEGA8 Error fix
Small fix in code
INPUT GAIN 0 to 15 db was wrong
change to 0 to 30db
files are updated
/Kim - Bascom-AVR user >> My WebChat
My Web Site
Old 12th January 2012, 02:51 PM   #705
aditya is offline aditya  India
Send a message via MSN to aditya Send a message via Yahoo to aditya
ok
one thng can we change input 1 ... to some thing like CD, FM , USB DAC, Phone , phone as in cell phone.. for usb dac i was thinking sinc there is a pin on PCM2704 which changes state when connected to pc. than we can use that pin to check for connection to pc so no need to touch the dial for changing channel if we connect to pc
Old 12th January 2012, 08:21 PM   #706
Jempie is offline Jempie  Indonesia
Originally Posted by tvicol View Post
Jempie,
LM1117DT is a low drop regulator. Use a trafo with min 6V ac - max 9V ac.
Tibi
Ok thanks
Old 13th January 2012, 12:22 PM   #707
FarmTech's Avatar
Originally Posted by aditya View Post
ok
Done CD, FM , USB DAC, Phone and center menu select on lcd
Added Portd.3 as SSPND
activ = low (auto select USB DAC)
! Note you cant change input while PORTD.3 IS LOW
files are updated
My Web Site
Old 13th January 2012, 10:19 PM   #708
farmtech,
why I hear hum when i disconnect any source, i don't think it's normal
if you compare it to another preamp you will hear nothing
se it seems that the input is open that is the sound i hear.
Old 14th January 2012, 01:32 PM   #709
FarmTech's Avatar
Originally Posted by Jempie View Post
farmtech,
I dont have this problem with my pcb setup
maybe you can show 1 picture of the insite of case
it can be lots of thinks gnd loops ect
My Web Site
Old 14th January 2012, 01:39 PM   #710
it's the same board as you can buy from tibi.
turn the volume up, and disconnoct the source you will hear hum
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2017 diyAudio
