Yet another Volume controlers and source selections - Page 66 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 24th December 2011, 09:56 AM   #651
aditya is offline aditya  India
Send a message via MSN to aditya Send a message via Yahoo to aditya
can i get the bass, mid , treb, and volume up down code..
using one encoder for up down and one button as set/enter
with out power on button. i would love it,
Old 24th December 2011, 09:58 AM   #652
Merry merry Christmas and happy happy and supper prosperous peace full new year
Old 24th December 2011, 08:29 PM   #653
FarmTech's Avatar
Send a message via MSN to FarmTech Send a message via Skype™ to FarmTech
about 7449 it dont have Mid-range tone thats TDA7439
but code is allmost the same ONLY BASS/Mid-range address is diffrent !!!!
see datasheet for both
Old 24th December 2011, 09:30 PM   #654
FarmTech's Avatar
Forgot to write that TDA7449 is 2 INPUT TDA7439 is 4 input
Old 25th December 2011, 05:50 PM   #655
i saw the project in elektor for TDA7449 but the LCD used in there is not available here. adn if i order it than its quite expensive for me. could you do a code for TDA7439 based on 8515 or atmega 8,
Old 25th December 2011, 05:59 PM   #656
FarmTech's Avatar
Hi Happy Hollyday .
Yes 8515 and M8 can be used for this
Iam working on code for 7439 for the lcd / encoder
hope to finish soon
I wait for the TDA7439 chip so I can test the code about 1 week then I have it
Old 26th December 2011, 02:33 AM   #657
cool, happy holidays, you can use proteus isis ( labcenter ) to check code squence coming on i2c port of the ic, and also the data thats coming on the LCD, and also test your codes
Old 26th December 2011, 03:31 AM   #658
FarmTech's Avatar
HI,
Yes I know proteus well
So we say M8 and 20x2 lcd or (16x2) portb
Intern clock 8Mhz (no crystal)
SDA/SCL TDA7439 portc 4/5
encoder portd 0-3 (maybe with push button)
Button menu/Select portd.4
Power On led portb.6
so you have change to make pcb
Old 26th December 2011, 04:13 AM   #659
Wayne Parham's Avatar
Here's one that uses an Analog Devices AD5206 RDAC and an Atmel AT2313 for stereo or AT4313 for home theater. The firmware for the home theater processor wouldn't fit into the 2313, but the 4313 is pin compatible, so they share the same schematic. The RDAC has linear pots, but a true logarithmic sequence is sent to it, providing an accurate log scale.
Merry Christmas!
Visit the π Speakers website
High-quality audiophile loudspeakers and kits
Old 26th December 2011, 07:07 AM   #660
Cool you use isis supper well you have a i2c debugger in the left column
Under a icon that looks like meters.
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2017 diyAudio
