Yet another Volume controlers and source selections - Page 63 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 26th September 2011, 01:38 PM   #621
Here is my code : http://ge.tt/89oox98?c
I would like to give me some hints to manage the problem with the clock as i had describe in post 618.
Old 26th September 2011, 07:58 PM   #622
Leon08 is offline Leon08  Germany
Banned
I think your problem is because you used the "case else" for this subroutine
Select Case Command
Case 16 : Call Vol_up
Case 17 : Call Vol_dw
Case 13 : Call Mute
Case 12 : Call Poweronoff
Case 62 : Call Menu
Case Else : Call Datetime
End Select
End If
The compiler translate it into an assembler code and it looks then completly different.
To make things worser this "select case works" different with other compilers.So I'm not sure how your compiler does translate it.
I would try a different approach like this:
Call Datetime
Select Case Command
Case 13 : Call Mute
Case 62 : Call Menu
End Select
End If
In this way the routine Datetime is separated from other routines.
Old 27th September 2011, 11:12 AM   #623
I had try this too but nothing happen still the same problem...
thanks for your help
Old 27th September 2011, 11:47 AM   #624
Banned
What is your problem exactly?
Old 27th September 2011, 01:41 PM   #625
When i'm increasing the volume with rc5 remote control and because the control sends low pulses i'm getting the clock between the numbers on my lcd
I have the volume : 15 , if i want to change the volume from 15 to 20, i'm holding the volume up button on the RC5 and start increasing but while i'm holding the button i'm getting the time between the numbers like 15-time-16-time-17-time-18-time-19-time-20... I'm try to fix this.
In general, i want the time to be on the screen only when i'm not using the remote control, when i'm increasing or decreasing or changing the balance of my speakers i want the time to be "hide"
Old 27th September 2011, 01:52 PM   #626
danzup is offline danzup  Romania
danzup's Avatar
Try this
There are not better tube than 6P3S and 6N2P for my ears !
Old 27th September 2011, 03:37 PM   #627
it does not work this too.
Old 28th September 2011, 08:55 PM   #628
FarmTech's Avatar
Send a message via MSN to FarmTech Send a message via Skype™ to FarmTech
Code:
Dim Time_call As Byte
If Pwr = 1 Then
    Getrc5(address , Command)
    If Address = 0 Then
    Time_call = 5 ' <<<<<<<<<<<< set to 5 or more
    Command = Command And &B01111111
    End If
  Select Case Command
  Case 13 : Call Mute
  Case 62 : Call Menu
  End Select
  If Time_call > 0 Then
   Decr Time_call
  Else
   Call Datetime
  End If
 End If
Old 29th September 2011, 09:27 AM   #629
thank you FarmTech it's working and to danzup and Leon08 for their time
Old 6th October 2011, 03:11 PM   #630
linuxworks's Avatar
Originally Posted by alexisk10 View Post
Has anyone did a digital volume control or preamp with Real time clock?
the one I designed does have all that: The LCDuino-1 Display I/O Processor (also search the delta1 and delta2 for the attenuator and input selector). all open source and with a huge amount of functionality.
My Photostream:http://www.flickr.com/photos/linux-works/
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2017 diyAudio
