Yet another Volume controlers and source selections - Page 55 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 5th July 2011, 05:46 AM   #541
Have someone firmware and schematic for atmega8 and tda7318 ??
Old 5th July 2011, 08:07 AM   #542
Have someone the firmware and schematic for atmega8 and tda7318??
Old 6th July 2011, 02:08 AM   #543
FarmTech's Avatar
Send a message via MSN to FarmTech Send a message via Skype™ to FarmTech
Lightbulb tda7318 atmega8
Hi morosanu22
you can use this code for atmega8
see post#393
schematic show atmega8515 use the pin setup in top of this bas for atmega8
have fun
Last edited by FarmTech; 6th July 2011 at 02:15 AM. Reason: forgot to add bas file :)
Old 6th July 2011, 05:49 PM   #544
I have done the schematic.
http://i51.tinypic.com/qq6fxe.jpg
Old 6th July 2011, 10:31 PM   #545
FarmTech's Avatar
Hi
Looks ok , remember PIN12 is for power on relay if you use this relay !!!
Old 11th July 2011, 03:32 AM   #546
Default ATMega8535
For anyone interested for using ATMega8535 (DIP Package in my case) R2R/Shunt Volume controller with RC5 learn and edit text input.
This is the firmware, thanks to Danzup and farmtech
Didiet
Old 22nd July 2011, 03:40 PM   #547
fotios is offline fotios  Greece
fotios's Avatar
Default PGA2310 Gain bytes transmission sequence?
Hi to all
I am building a similar PGA2310 control like this of danzup, simply i use as host controller a PIC16F887 (i have only PIC programmers). From the timing figures of PGA2310 i can suppose that, the transmission sequence of Gain bytes from the host controller to the PGA2310 SDI is:
L0-L1-L2...-L7-R0-R1-R2...-R7 or Left channel bit0 first - Right channel bit7 last.
Is this sequence correct? Or is the inverse sequence correct?
Thanks for any information
Fotios
Best Regards FOTIS ANAGNOSTOU
Old 23rd July 2011, 10:05 PM   #548
fotios's Avatar
Default Lost reply
That was very funny
I received a reply from ------- (he knows, just from respect to him i don't refer his name) in my mail-box and from hurry i deleted the message without read it, because was from diyAudio. When i got into thread the reply was deleted! So, i pulled up the mail from the server of my ISP.
BTW, thanks ------- for the reply, you are very kind. Thanks for your suggestions, but i have proceed enough in my program that is some different from yours, because i use Latching relays and rotary encoder. This moment i am in the process to program the Balance control for PGA2310 and it remains to paste the remote control receiver software. I have all parts needed and i make PCBs at home.
Just i asked the receive sequence of Gain bytes from PGA2310 SDI to be sure. When my project completed, i can share it with you, no problem.
Fotios
Old 26th July 2011, 05:54 PM   #549
danzup is offline danzup  Romania
danzup's Avatar
Fotios when i was writing the firmware i was reading the data sheet and implementing the protocol from there .
If you read my firmware you will understand .
If you need more help just say .
(Sorry I do not have time like those days , even on diyaudio I enter once a week now .)
There are not better tube than 6P3S and 6N2P for my ears !
Old 3rd August 2011, 12:51 PM   #550
i would like to make a volume bar graph on my LCD for my system. i had try to do it but when i push the button for the volume up the bar goes at the end with every push on the button.
Here is the code that i use for the volume up :
If Command = 16 Then
If Volume < 15 Then
Cls
Locate 1 , 2
Lcd " Volume: "
Incr Volume
Locate 1 , 11
Lcd Volume
Locate 2 , 2
For position = 1 To 16
For Bar = 2 To 6
Locate 2 , Position
Lcd Chr(bar)
'Waitms 700
Next
Next
Else
Locate 1 , 11
Lcd "MAX!"
End If
End If
Any ideas? (Im using bascom)
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
Copyright ©1999-2017 diyAudio
