Go Back   Home > Forums > Source & Line > Analog Line Level
Old 25th February 2011, 11:56 PM   #501
I did not disable Jtag and setup clock to internal 8Mhz.
I am not sure how to do this. I used the Atmel STK500 to program.
I will make an attempt to do this.
Thanks for your help.
Dave
Old 25th February 2011, 11:57 PM   #502
FarmTech's Avatar
Send a message via MSN to FarmTech Send a message via Skype™ to FarmTech
program Avr studio ?
Old 1st March 2011, 05:07 PM   #503
I was able to set the Fuse bits, but I still have a problem.
As soon as +5V is applied, the display reads "10", then one second later, the display turns off and no other functions work.
Any ideas?
Thanks.
Old 1st March 2011, 07:29 PM   #504
FarmTech's Avatar
Any ideas?
Thanks.
Hmm, I dont have this version so I cant give info about it
And nothing happens if you press POWER button ?
But of cause you setup Jumpers as R2R like on image
And the jumper on main-bord to for R2R !!
else contact them for help/support
Old 2nd March 2011, 01:56 PM   #505
danzup is offline danzup  Romania
danzup's Avatar
Any ideas?
Thanks.
Only the power button will work after power down !
So it is in firmware and from what is telling me it is ok how that controller react .
Do not power on after press power on button ?
Please send more info for me to help you .
There are not better tube than 6P3S and 6N2P for my ears !
Old 3rd March 2011, 04:12 PM   #506
Hi Danzup,
Thanks for your reply.
Yes, the "On/Off" switch, S2, does turn on the volume control.
I thought the S2 switch was used to turn on an external device, like a power amp. I did not realize that after applying +5v to the board, the "On/Off" switch needed to be pushed.
I was confused.
It works now and I am continuing to built it into my pre-amp.
Thanks,
Dave
Old 4th March 2011, 06:35 AM   #507
danzup's Avatar
This is the truth : but the controller power up at the same time with the amplifier !
And for the time the controller is powered up so does the power amplifier .
Old 21st March 2011, 06:47 PM   #508
Hi Danzup,
I have been integrating your board into my preamp, and am having problems with the remote control function.
I have tried several universal remotes that I have. I just cannot seem to get any response.
I read in an earlier post that you might have a Sony remote code version of your software. If so, I would like to try the Sony version.
Thanks,
Dave
Old 22nd March 2011, 06:45 AM   #509
danzup's Avatar
Hi Danzup,
Thanks,
Dave
I recommend to you to use the "farmtech no vu" firmware and use that firmware to reprogram the key with your RC5 remote .
Read again few pages on this thread and use that firmware because it is more flexible about remote control . My firmware accept only small number of RC5 remote .
Old 22nd March 2011, 03:29 PM   #510
FarmTech,
I looked at your "farmtech no vu" firmware to fix my remote problem, and noticed it is made for the LCD version.
I am using an LED and was hoping you could add the RC5 learning remote function to the LED firmware.
I know this is a lot to ask, but would greatly appreciate your help.
Thanks,
Dave
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 07:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 05:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 03:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 06:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 05:23 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
