Yet another Volume controlers and source selections - Page 50 - diyAudio
Go Back   Home > Forums > Source & Line > Analog Line Level
Old 15th February 2011, 08:51 AM   #491
stk500 is offline stk500  Germany
Hi kim!
Thank you!
maybe you no me Understand, I say , I push you name in my programm Code,because I take your code programm to experiment and my project.
in Germany Forum ist Ok but my Job is Sound, ok, this ist one motiv to coming in Diyaudio
Thank you
stk500
Old 16th February 2011, 12:02 AM   #492
FarmTech HI! HI ALL!
Greetings!
tell me is there a firmware for the M16 + PGA + LCD & VU +4 in + RC5
and what scheme is used for your firmware?
I'm sorry I'm new
Old 16th February 2011, 02:21 AM   #493
FarmTech's Avatar
Send a message via MSN to FarmTech Send a message via Skype™ to FarmTech
Greetings!
I'm sorry I'm new
Hi
No its for Projetc nr.3 see post #4
and Post #348 VU-meter addon
but to get the full storry you have to read the hole Thread lots of addon is made for Danzups controller 1.6C
start at post #3 and read
Old 16th February 2011, 10:34 AM   #494
Originally Posted by FarmTech View Post
Hi
I understand you!
Thank you very much for your attention
Be a problem for you, "tie"to your firmware management for PGA?
Old 16th February 2011, 04:29 PM   #495
FarmTech's Avatar
I understand you!
A the moment Iam making a motorpot version
but have no plans for making a PGA2311 version
If you read the posts you will find code for a PGA2310 version
and you can edit the software for M16
Old 16th February 2011, 04:34 PM   #496
OK! response received! sorrowfully
'll do on the weekend to begin prototyping
Old 25th February 2011, 09:16 PM   #497
I just completed building the latest Rev 2.1.b.
After I apply power, the LED reads "10", and I can adjust the volume up or down. So it seems to work. I am using the R2R settings.
My problem is: After about 5 sec, one of the relays clicks, and the LED goes off.
If I recycle power, it does the same thing again.
Has anyone experienced this, or know what might be the problem?
Thanks,
Dave
Old 26th February 2011, 12:14 AM   #498
FarmTech's Avatar
What software version do you use ?
Old 26th February 2011, 12:27 AM   #499
I not sure what version I used. It was the .hex file that I received from Vicol Audio when I ordered the bare board.
It is called: ATM16_SHUNT_R_2R_LED.HEX
Old 26th February 2011, 12:35 AM   #500
FarmTech's Avatar
Ok and when you program chip
you remember to disable Jtag
and setup clock to 8Mhz int ?
Link LCD Atmel software ATM16_SHUNT_R_2R_LCD_V1.zip Vicol Audio
source selector / volume hum in Aikido cbutterworth Tubes / Valves 1 28th March 2007 08:34 AM
Source for volume knobs? Alois Pass Labs 4 3rd July 2005 06:12 PM
IC Controlers for Class D Power stage frozenpod1 Class D 14 17th May 2005 04:25 PM
Swichable source and volume pot. Whats the best way? sounder Chip Amps 2 22nd September 2003 07:29 PM
detented volume pots... source? Mach_Y Parts 2 1st June 2003 06:23 PM
Copyright ©1999-2017 diyAudio
