| Analog Line Level Preamplifiers , Passive Pre-amps, Crossovers, etc. |
#41 | |||
Right you are - for sound MLT are perfect! Quote:
#42 |
There are not better tube than 6P3S and 6N2P for my ears ! |
#43 |
Well done!
#44 |
Danzup,
thank you very much for sharing your knowledge and experience with us. I decided to make your R 2R controller (post #4 sch and #36 prog), but I fell down on first step. I wanted to use DIL40 ATMega16 to avoid SMD components, but then I haven't enough pins (40 instead of 44). Do you have solution for me (everything the same, only without SMD)? No, I'm poor Serbian and I can't buy ready made PCB's from you, I have to do all by myself. In any case, thank you very much again. |
#45 |
I apologize, now I saw the difference between PDIP and TQFP packages. No, I'm not so stupid (maybe I am), I was just too fast.
I'll inform you how my work develops. Greetings |
#46 | |
Yes , you can do on perf board the whole project , as it was my first r/2r controller and the microcontroller was the atmega16 - dip 40 , no problems about as you stay with the plans . Good luck !
There are not better tube than 6P3S and 6N2P for my ears ! Last edited by danzup; 5th December 2009 at 05:34 AM. |
#47 |
Hi danzup,
this is a very interesting thread, actually exactly what I am looking for. I am especially interested in your project #3, i.e. r/r2, and I read most of the romanian part of it you linked to. Would it be possible to integrate a jog dial for switching signal purposes ? Couldn't find any info on linking the remote signal to manual inputs. PS: You should have a PM about r/r2 Again, your work looks great! |
#48 | |
When you press Menu button you switch between Volume adjusting or Input selection with the existing jog ! On the remote there are using Ch+ and CH- for Input selection Vol+ and Vol- for Volume adjusting , mute button , button 1 to 4 for direct selections of the input , Power on/off for remote power on/off. On the front panel buttons work like this : press once menu -->adjust volum with jog ---> press again menu --> adjust input selection ---> and so on . Also there is a on/off button. PS : I have received the PM , the response is here .
There are not better tube than 6P3S and 6N2P for my ears ! Last edited by danzup; 30th December 2009 at 10:10 AM. |
#49 |
Hello, Danzup!
At first let me join my colleagues expressing here their respect for your great work, but more - for willing to share your work for free. Indeed, I also think THIS IS HOW IT SHOULD be, all over the human society, but unfortunately - we are in minority. Sorry for long preamble I am going to repeat your project(PGA version), but with slight changes - going to use Atmega in QFP and PGA2310 in SOL-16 packaging, which would require PCB change. IF you have a PCB drawing for such a combo - I would appreciate getting it, if no - I would appreciate getting an editable drawing(source) of the PCB, if that's also not an option - I would develop my own (just being lazy and trying to save work - but youve' done THE WORK anyway Man, your'e great! Keep it like this! P.S. ... regarding your signature - believe me, there are much better tubes than 6P3S and 6N2P (however this turns to be offtopic here)!
#50 | |
let me say that the majority of my project was realised on perfboard as it was more speedy that way . All the PCB for different project was not made by me , but by a friend of mine . There are not PCB like you asked for but the other day , by request , I have urged one of my friend ( jkraxy is the nick name on diyaudio ) to do such an PCB as asked you ( it is like reading my mind ) !! But will be some time till will be over . So keep looking here for what will come . ---------------------------------------------- In the picture is a PGA2310 on perfboard :
| Currently Active Users Viewing This Thread: 2 (0 members and 2 guests) | |
| source selector / volume hum in Aikido | cbutterworth | Tubes / Valves | 1 | 28th March 2007 07:34 AM |
| Source for volume knobs? | Alois | Pass Labs | 4 | 3rd July 2005 05:12 PM |
| IC Controlers for Class D Power stage | frozenpod1 | Class D | 14 | 17th May 2005 03:25 PM |
| Swichable source and volume pot. Whats the best way? | sounder | Chip Amps | 2 | 22nd September 2003 06:29 PM |
| detented volume pots... source? | Mach_Y | Parts | 2 | 1st June 2003 05:23 PM |
| Page generated in 0.13828 seconds (85.38% PHP - 14.62% MySQL) with 11 queries |
